Scientific papers
Open access scientific publications and research papers about UAV and drone mapping, including accuracy studies, pioneering photogrammetry techniques, and proven best practices.
Tip: Check the Pix4D Blog for more use cases and applications in which UAV and drone mapping is used.
Classification of aerial photogrammetric 3D point clouds
C. Becker, N. Hani, E. Rosinskaya,
E. d’Angelo, C. Strecha
Open PDF
Photogrammetric accuracy and modeling of rolling shutter cameras
J. Vautherin, S. Rutishauser,
K. Schneider-Zapp, H.F. Choi,
V. Chovancova, A. Glass, C. Strecha
Open PDF
Terrestrial 3D mapping using fisheye and perspective sensors
C. Strecha, R. Zoller, S. Rutishauser,
B. Brot, K. Schneider-Zapp,
V. Chovancova, M. Krull, L. Glassey
Open PDF
UAV collision and crime scene investigation
Simplified building models extraction from ultra-light UAV
O. Kung, C. Strecha, P. Fua1, D. Gurdan, M. Achtelik, K-M. Doth, J. Stumpf
Open PDF
Automatic mapping from ultra-light UAV imagery
C. Strecha, O. Küng, P. Fua
Open PDF
Photogrammetric performance of an ultra-light weight swinglet UAV
J. Vallet, F. Panissod, C. Strecha,
M. Tracol
Open PDF
Wide-baseline stereo from multiple views: a probabilistic account
C. Strecha, R. Fransens, L. Van Gool
Open PDF
A generative model for true orthorectification
C. Strecha, L. Van Gool, P. Fua
Open PDF
The accuracy of automatic photogrammetric techniques on ultra-light UAV imagery
C. Strecha
Open PDF
Dense matching of multiple wide-baseline views
C. Strecha, T. Tuytelaars, L. Van Gool
Open PDF
The Chillon project: aerial / terrestrial and indoor integration
C. Strecha, M. Krull, S. Betschart
Open PDF
Dynamic and scalable large scale image reconstruction
C. Strecha, T. Pylvänäinen, P. Fua
Open PDF
How accurate are UAV surveying methods
B. Draeyer, C. Strecha
Open PDF
3D error estimation from tie points
C. Strecha
Open PDF
Assessment Of The Radiometric Accuracy In A Target Less Work Flow Using Pix4D Software
M. Cubero-Castan, K. Schneider-Zapp, M. Bellomo, D. Shi, M. Rehak, C. Strecha
Open PDF
A new method to determine multi-angular reflectance factor from lightweight multispectral cameras with sky sensor in a target-less workflow applicable to UAV
To access the full article visit the journal of Remote Sensing of Environment or read the preprint.
Seeing the Invisible, Multispectral Image Analysis in Arable Farming
H. Battke, K. Schneider-Zapp
Open PDF
Investigation on the
positional accuracy of 3D models
generated by the Pix4Dcatch app
synchronized with the
viDoc RTK rover for iPad
F. Murgia, A.Mitache, M. Rehak,
C. Strecha, B. Vidmar
Open PDF
Site calibration with PROJ and WKT2
J. Jimenez Shaw, J. Hernando, C. Strecha
Open PDF
