How to fly and process the DJI Mavic 3 Multispectral (M3M) in PIX4Dfields
This article explains how to properly set the DJI Mavic 3 Multispectral (Mavic 3M, DJI M3M) before flying and how to process the images in PIX4Dfields.
Introduction
The DJI Mavic 3 Multispectral is equipped with a 20-megapixel RGB camera and a 5-megapixel, 4-band multispectral camera. Additionally, it features an RTK antenna for enhanced precision.
Flight settings recommendations
- Depending on the task, capture both RGB and multispectral imagery or capture only one type of image. The RGB camera produces .jpg images while the Multispectral camera produces .tiff images. For each capture, one RGB and four multispectral images will be generated.
- Use a high-speed microSD card rated V30 or above.
- Ensure that Dewarping is turned off before capturing RGB images.
- Access the camera menu and click on the settings.
- Ensure Dewarping is toggled off .
- When Dewarping is disabled, the images will display a black vignette in the corners:
This is expected and perfectly fine. The distortions are removed by PIX4Dfields during the processing. - When processing images with dewarping enabled, and it is detected via the EXIF of the images, PIX4Dfields will display:
"Data acquired with 'dewarping' turned on. Images were taken with the drone's Dewarping feature turned on".
Images can still be processed; however, it is recommended to disable this feature for future flights, as it may cause the resulting maps to be shifted by several meters, compromising both relative and absolute accuracy.
- Avoid using the "Elevation optimization" feature, as it will cause the drone to capture non-nadir images toward the end of the flight.
- Including these images in your dataset can degrade data processing quality. If such images are present, reprocess your dataset without them.
- To disable Elevation Optimization, go to Flight Route creation, below Route Altitude, toggle Elevation Optimization off.
- The flight height directly influences the resolution, Ground Sampling Distance (GSD), of the images. Below is a table and a visual comparison illustrating how different flight heights impact the GSD, Flight Time and Speed.
* Flying with similar settings may not yield the exact values shown above. These values are estimates and might not be entirely precise.
What Reflectance panel should I use?
- The multispectral camera is not fully radiometrically calibrated, as the manufacturer only does a relative calibration. All bands are calibrated against the standard NIR band. Therefore, the camera will not provide reflectance factors but only relative values proportional to reflectance.
- A reflectance panel, also called calibrated reflectance panel/target or reflection panel, is required to obtain reflectance factors.
Only Micasense and Sentera targets are compatible with the Mavic 3 Multispectral.
- Micasense compatible panels:
- Sentera compatible panel:
- Parrot NOT COMPATIBLE panel:
- Without such a target, only self-normalizing indices produce meaningful results, i.e. indices that don't depend on the absolute value. Examples of such indices are NDVI, NDRE, VARI, SIPI2, LCI, BNDVI, and GNDVI. Not self-normalizing are TGI and MCARI.
- For more information: Radiometric corrections.
How to process the M3M in PIX4Dfields
When processing in PIX4Dfields, each camera has to be processed separately. If both images are imported, a message will pop up to choose one.
The orthomosaic generated from multispectral images will exhibit a pink color balance. This color shift occurs because the blue band is absent in the multispectral data, and unfortunately, there is no method to correct this issue.
For generating a true color orthomosaic, it is essential to process the RGB images instead.
The Digital Surface Model of the M3M may display wrong values; please read Wrong elevation on the DSM.
Example dataset
To access the example imagery of the DJI Mavic 3 Multispectral, please visit: https://www.pix4d.com/dji-mavic-3-multispectral-dataset/
