OPTION | DESCRIPTION |
Speed |
Defines the drone's speed from a range between Slow and Fast (default). The maximum speed depends on the selected overlap and flight altitude. The scale has six levels corresponding to percentages of the maximum speed between 100% (Fast) and 50% (Slow). The speed should fluctuate between 2 and 8 m/s and is not constant during the flight since the drone slows down to trigger pictures. |
Angle (°) |
Defines the tilt (not pan) of the camera between 0°, horizontal, and 90° (default), vertical. The default value is vertical but if it was changed previously, the angle is the one of the last planned mission. |
Overlap (%) |
Defines the front overlap between 70%, 80%, and 90%. For more information about how to set the overlap: Step 1. Before Starting a Project > 1. Designing the Image Acquisition Plan > a. Selecting the Image Acquisition Plan Type. The side overlap is computed such that the side distance between two images is twice the front distance meaning the distance between two images on the same flight line. The side overlap is adjusted with the number of lines so that it is close to the defined overlap value. |
Face |
Defines whether the drone should be oriented towards the center of the mission when taking pictures, Center, or not, Forward (default). The point of interest should be the middle of the area to map. |
I just wanted to try this out
