(Android) Pix4Dcapture Release 3.5
Download Pix4Dcapture for Android via Google Play (click below for direct access):
3.5.1 December 28, 2016 Bug fix
3.5.0 December 07, 2016 New
Compatible drones
  • DJI Inspire 1 and Inspire 1 Pro (I1).
  • DJI Mavic Pro (MP).
  • DJI Matrice 100 (M100).
  • DJI Phantom 2 Vision (P2V).
  • DJI Phantom 2 Vision+ (P2V+).
  • DJI Phantom 3 Advanced (P3A).
  • DJI Phantom 3 Professional (P3P).
  • DJI Phantom 3 Standard (P3S).
  • DJI Phantom 4 (P4).
  • All other DJI drones supporting SDK 3: Not tested. Pix4D cannot guarantee that it will work with other drones.
  • Parrot Bebop 2 (B2).
  • 3DR Solo (Solo): beta
_ Important:
DJI drones do not support the same SDK.
  • Support of SDK 3: I1, M100, MP, P3A, P3P, P3S, P4.
  • Support of SDK 2: P2V, P2V+.
For drones supporting SDK 3, a complementary app has to be installed together with Pix4Dcapture: Ctrl+DJI. It is important to use the latest version of this plugin together with the latest Pix4Dcapture version. Download Ctrl+DJI for Android via Google Play (click below for direct access):
Notes
  • No circular mission available for DJI drones but the camera can be adjusted to face the center of the grid.
  • Beta support of 3DR Solo with GoPro Hero 4 (Black or Silver) only.
Version 3.5.1
Improvements
  • (DJI) The drone now rotates and always looks forwards when moving even if the camera angle is set to vertical. It means the drone turns in the angles of the grid mission to go from one line to the other.
Bug fixes
  • (DJI) Improved stability for picture triggering.
  • (DJI with X5) Camera was not shooting because of a too short time interval to trigger the picture. The drone now flies slower but the Zenmuse X5 should shoot without problem.
  • Various bug fixes.
Known bugs
  • (Inspire 1, Matrice 100) When flying with a Zenmuse X5 camera, the automatic synchronization that usually starts at the end of the flight fails. The mission should be synchronized manually but it could still fail. For more information: 204716225. In this case, processing without the .p4d file is recommended. For more information: 204911905.
Version 3.5.0
What is new
  • Support of DJI Mavic Pro.
Note: DJI Mavic Pro will not land automatically. Taking manual control at the end of the flight is necessary for landing the drone.
Bug fixes
Known bugs
Powered by Zendesk
