How to import Pix4D data into IMS Map360
Pix4D, IMS Map360 and Evidence Recorder projects can be merged into a single Map360 project.
- When collecting Ground Control Points and any additional points and linework when using Evidence Recorder and a GPS Receiver.
- When selecting the Output Coordinate System in Pix4D. For more information: Menu Project > Select Output Coordinate System....
- When setting the Project Coordinate System in IMS Map360.
In Pix4Dmapper:
1. Create a new project in Pix4Dmapper: Step 2. Creating a Project.
2. Import the images: Step 2. Creating a Project.
3. Select Output coordinate system: Step 2. Creating a Project.
4. Select Processing Options template: Step 2. Creating a Project.
5. Click Finish.
6. Click Start Processing.
To import the pointcloud into IMS Map360 project:
1. Click New Scene to create a drawing.
2. Click Scene Defaults... the General Configuration Options window appears.
3. Click OK.
4. On the Import/Export >Import Cyclone.
5. Connect to the EpcA engine and connect IMS Map360 to Cyclone.
In Cyclone:
1. Expand the drop-down list SERVERS and right click on computer_name database.
2. In the Configure Databases window on computer_name window click Add...
3. Navigate to the path where the .las file is stored.
4. In the Create/Select a Cyclone DB window enter a name and double click Open.
5. Click OK.
6. If the database is included in the list click Close.
7. In the Cyclone-VIEWER-Navigator window right click on the database generated and click Import...
8. Browse to the .las file and click Open.
9. In the Cyclone-VIEWER-Navigator window expand the database that was created and the ModelSpace will appear.
10. Close Cyclone.
In IMS Map 360:
1. Return to the drawing and use the Open Cyclone command on the Import/Export tab (Sketch mode) or on the PointCloud tab (Advanced mode) or type CWIMPORT at the command line.
2. On the Import ModelSpace View window set the units to Meters and click ... to import the model.
3. Expand the database tree and on the My LAS file database right click Create View.
4. Then click + to expand the tree.
5. Select ModelSpace View and click Open.
6. Click OK.
7. The point cloud is imported.
For more information: http://ims.microsurvey.com.
Third-party information disclaimer:
PIX4D provides instructions for third-party platforms and products solely as a helpful guide to unblock your integration. Those companies are independent of PIX4D. We do not maintain, control, or guarantee the performance, accuracy or reliability of these products.
PIX4D may provide third-party links or contact information to help you find additional information about this topic. This contact information may change without notice. PIX4D does not guarantee the accuracy of third-party documentation or contact details.
