(Android) Pix4Dcapture Release 3.3
Download Pix4Dcapture for Android via Google Play (click below for direct access):
3.3.1 October 21, 2016 Bug fix
3.3.0 October 14, 2016 New, bug fix
Compatible drones
  • DJI Inspire 1 and Inspire 1 Pro (I1).
  • DJI Matrice 100 (M100).
  • DJI Phantom 2 Vision (P2V).
  • DJI Phantom 2 Vision+ (P2V+).
  • DJI Phantom 3 Advanced (P3A).
  • DJI Phantom 3 Professional (P3P).
  • DJI Phantom 3 Standard (P3S).
  • DJI Phantom 4 (P4).
  • All other DJI drones supporting SDK 3: Not tested. Pix4D cannot guarantee that it will work with other drones.
  • Parrot Bebop 2 (B2).
  • 3DR Solo (Solo): beta
_ Important:
DJI drones do not support the same SDK.
  • Support of SDK 3: I1, P3A, P3P, P3S, P4.
  • Support of SDK 2: P2V, P2V+.
For drones supporting SDK 3, a complementary app has to be installed together with Pix4Dcapture: Ctrl+DJI. It is important to use the latest version of this plugin together with the latest Pix4Dcapture version. Download Ctrl+DJI for Android via Google Play (click below for direct access):
Notes
  • No circular mission available for DJI drones but the camera can be adjusted to face the center of the grid.
  • Beta support of 3DR Solo with GoPro Hero 4 (Black or Silver) only.
Version 3.3.1
Bug fixes
  • Upload to the cloud with mobile data could fail (did not apply to Wi-Fi connection).
  • Various bug fixes.
Known bugs
  • (Inspire 1, Matrice 100) When flying with a Zenmuse X5 camera, the automatic synchronization that usually starts at the end of the flight fails. The mission should be synchronized manually but it could still fail. For more information: 204716225. In this case, processing without the .p4d file is recommended. For more information: 204911905.
Version 3.3.0
What is new
  • Alternative providers can be selected for the street or satellite base map. In the Home screen, tap Settings. In the Settings menu, go to the section Maps and tap the corresponding option and choose from the drop-down list.
    • Possibility to select another provider than MapBox (default): USGS, ESRI, etc.
    • Possibility to add another base map provider.
Note: Only MapBox (default) base map can be saved on the device and used as offline maps.
  • Permissions related to the license for uploading a project to the cloud. For more information: 213666646.
Improvements
  • Faster upload (parallelized) to transfer the full resolution images and project file (.p4d) to the cloud.
Bug fixes
  • (DJI drones except P2V and P2V+) Images were not captured during the flight because of the format that was selected in DJI GO. The drone should now take .jpeg pictures regardless of the format that is defined.
  • The .p4d file generated at the end of the mission used to contain wrong parameters for the camera orientation. These orientation parameters are now not written in the .p4d because they are not needed for processing with the software.
Known bugs
0 out of 0 found this helpful
Powered by Zendesk
