Pix4Dmapper 3.0 Preview Technical Release Notes
This is the release of Pix4Dmapper 3.0 Preview. Get a preview of the new features and help us improve the product by reporting any issues Submit a request to support.
Disclaimer: the documentation is not yet ready for 3.0 Preview, and we do not recommend using the Preview for production work. No support is provided for the Preview.
Download
VersionRelease dateRelease type
3.0.13 October 11, 2016 New release
3.0.7 September 26, 2016 Preview
3.0.5 September 6, 2016 Preview
3.0.3 August 23, 2016 Preview
Version 3.0.13
Bug fixes
  • Processing
    • Fix bug where the calibration results were less accurate for some oblique datasets.
    • Fix bug where for some AG-RGB or Thermal datasets step 1 was slower.
    • Fix bug where it was not possible to run step 3 again after step 3 was done. This happened only in the case where the software was not closed before starting step 3 again.
  • Index calculator
    • Fix various bugs affecting radiometric calibration and the reflectance map generation.
    • Fix bug where radiometric calibration was not reseted correctly after pressing the Reset button.
    • Fix bug where regions exported in .shp format from the Index Calculator could not be imported.
    • Fix bug where the reflectance map computed using the Gaussian Fast Downsampling Method was not computed correctly anymore. This bug was introduced in version 3.0.7.
  • rayCloud
    • Fix bug where surfaces could not be renamed.
Version 3.0.7
What is new
  • Index calculator
    • New processing options in the options for step 3 > Index Calculator > Radiometric Processing and Calibration that allow to select the radiometric correction type:
      • No Correction
      • Camera Only
      • Camera and Sun Irradiance
      • Camera, Sun Irradiance and Sun Angle
  • Quality report
    • Display radiometric correction type used.
Improvements
Bug fixes
  • Merging projects
    • Fix bug where after merging projects, the Index List in the processing options for step 3 > Index Calculator was empty.
  • 3D Textured Mesh
    • Fix bug where the texture of the 3D textured mesh had black parts when using 360° cameras and the Global Masking feature.
  • Index calculator
    • Fix bug where software crashed when opening the the Index Calculator after having merged projects.
Known issues
  • Processing
    • For some AG-RGB or Thermal datasets step 1 is slower.
    • Fast gauss downsampling option of the reflectance map does not discard properly nodata values and the results contains artifacts.
      Workaround: use the average gauss for acurate results.
    • For some oblique datasets, some regression in time/completeness may occur.
  • Quality report
    • Quality report pdf is not overwritten if it is open.
      Workaround. Close the pdf before re-generating the quality report.
  • rayCloud
    • Cannot rename surfaces.
  • Index calculator
    • Radiometric calibration image paths are not updated when changing the project's location. If processing is done after a project is moved the radiometric calibration will not be done.
      Workaround: In the processing options under step 3 > Index Calculator, update manually the path for all the radiometric calibration images.
    • Cannot reprocess step 3, warning w0033: somes result files or folders are already open.
      Workaround: Save, close the project and reopen it.
  • Volumes
    • Base surface changes are not taken into account when exporting volumes.
Version 3.0.5
What is new
  • Index calculator
    • Faster reflectance map generation when using a value higher than the GSD for the resolution and selecting the Gaussian Fast Downsampling Method.
Improvements
  • Camera models
    • Linear rolling shutter is set as default for the Sequoia RGB camera model.
  • Processing
    • Improve feature extraction for 360° cameras so that more features are extracted on the top and bottom of the images.
Bug fixes
  • Project management
    • Fix bug where when a 2.2 project was opened in 3.0.3 preview, no backup was created and the project could not be opened in 2.2 anymore.
  • Coordinates system
    • Fix bug where GCP and output coordinate system were not automatically updated when changing the image coordinate system from arbitrary to known coordinate system after the project has been created.
  • Camera models
    • Fix bug where no camera model from the user database could be selected.
  • rayCloud
    • Artifacts are visible when displaying the thermal shader for the Mesh on computers with AMD cards.
  • Index Calculator
    • Albedo field for the radiometric calibration does not accept a value with a '0'.
  • Various UI bug fixes
Other changes
  • EULA
  • Processing options
    • Discontinue the option in step 2 > Advanced > 3D Textured Mesh Settings > Maximum Number of Triangles per Leaf.
  • Processing area
    • Discontinue the import of the processing area in DXF format.
Known issues
  • Merging projects
    • When merging projects, the Index List in the processing options for step 3 > Index Calculator is empty.
      Workaround: After merging projects, close the software and re-open it.
  • Quality report
    • The Ground Control Points table is not displayed in the Quality Report for projects without image geolocation, even though the GCPs are taken into account for processing
  • Volumes view
    • When importing volumes from a file, if multiple volumes have the same name, they are imported as one volume.
    • Exporting volumes always contains the default base surface, even if it was changes in the settings.
  • Index calculator
    • Software crashes when opening the the Index Calculator after having merged projects.
Version 3.0.3
What is new
  • Processing
    • Point cloud densification is up to 2x faster while preserving quality and density.
Improvements
  • Various UI improvements
Bug fixes
    • Fix bug where project could not be opened when it was created with version 2.2 and the processing option Use MTPs under 1. Initial Processing > Matching > Matching Image Pairs > Custom were unselected.
  • Map View
    • Fix bug where an error was shown when double clicking on a multispectral image in the Map View.
  • Processing
    • Fix bug where the texture file was not generated when generating the 3D Textured Mesh in OBJ format. This happened when creating a new project and directly processing it.
    • Fix bug where the orthomosaic generated from a project with Sequoia's RGB images was fully transparent.
Known issues
  • Processing
    • 3D Textured mesh has a gray texture when using color balancing. The bug appears when generating the mesh first during step 2 and then re-generating it using the menu Process > Generate 3D Textured Mesh.
  • rayCloud
  • Index Calculator
  • Pix4Dmapper Mesh
    • Cannot use surface objects to improve the mesh.
    • Cannot export a Mesh from the layers sidebar in the rayCloud.
0 out of 0 found this helpful
