How to export Volumes - PIX4Dmapper
  Access: This option is enabled only if at least one Volume is created.
To export the Volumes:
1. On the Menu bar, click View > Volumes.
2. On the sidebar, in the Objects section, click  .
3. (optional) Click All to select all Volumes to be exported, click None to unselect all Volumes or select the checkbox on the left of each Volume to select some of the Volumes to be exported.
  Note: By default, if one Volume is selected before starting the Export process, only this Volume is selected to be exported. If no Volumes are selected in Volumes before starting the Export process, all Volumes are selected to be exported.
4. Click Export..., the Export pop-up opens:
  Important: The volume will be exported as a polygon with Z values for each vertex.
5. Navigate to the path where the object will be saved.
6. On File name, type the desired file name.
7. (optional ) On Save as type, by default ESRI Shapefiles (*.shp) is selected; select another output format using the drop-down menu:
- ESRI Shapefiles (*.shp)
- AutoCad DXF (*.dxf)
- Microstation DGN (*.dgn)
- Keyhole Markup Language (*.kml)
8. Click Save.
