How to process Images that are covered by a consistent Obstacle
If a project consists of images that are covered by a consistent obstacle, e.g. the foot of the drone, the model might be noisy. It is possible to annotate the obstacle to not take it into account for processing so as to remove the noise introduced.
To remove the obstacle from the results:
1. Click View > rayCloud.
2. In the section Layers of the left sidebar, select one image to be annotated.
Important: It is enough to annotate only one image; the annotation is propagated to the same pixels of all the images and therefore the obstacle will be annotated in all the images.
Important: The obstacle should appear in the same position in all the images to use the Global Mask annotation since the annotation is propagated in all the images.
3. In the right sidebar, click the Annotation tool button pencil.png.
4. In Annotate, select Global Mask.
5. Annotate the obstacle in the image, following 202560549 (steps 7-13).
6. Make sure that the Use Annotation box is selected in the Processing Options202560549 (step 14).
7. Process step 2. Point Cloud and Mesh.
0 out of 0 found this helpful
Powered by Zendesk
