Index > Interface > Menu View > Volumes | Previous | Next |
The following options are displayed:
A Volume is an object that can be used for volume calculations. It is defined by a 3D Surface called base surface. The volume is computed between the base surface and the terrain surface, defined by the DSM.
For step by step instructions about how to draw a new volume: How to draw a Volume.
Once a New Volume is created, the Sidebar displays the following information: Menu View > Volumes > Sidebar > Objects.
1- Select and delete multiple "volumes" at the same time
2- Export of "volumes" with all attributes, such as volume values in tables or SHP.
Completely Agree Marcio, Virtual Surveyor easily allows your do to do this .... Come on Pix4D
Hi,
Thank you for your feedback; it's precious. I made a note and passed it on to the right people.
