Which Value should be entered for Albedo when using a radiometric calibration Target
When using a radiometric calibration target, the value of 0.5 for each band should not be kept. This value is a placeholder. The value that should be entered depends on the radiometric calibration target, and can typically be provided by the card manufacturer. It should be the reflectance (or albedo) value for the central wavelength of the associated band.
1 out of 1 found this helpful
