Pix4Dcapture offers the possibility to fly four different kind of autopilot missions and one manual but semi-automatic mission.
To get the best results out of the image acquisition plan, the type of mission and the drone have to be chosen depending on the terrain/objects that need to be reconstructed. For more information:
- Step 1. Before Starting a Project > 1. Designing the Image Acquisition Plan > a. Selecting the Image Acquisition Plan Type.
- Supported drones and cameras.
Type of mission | Description |
Plan and fly a nadir rectangle mission. Suitable for most environments. It ensures that images are taken with the overlap required for optimal processing. Recommended in the following cases:
Plan and fly a two consecutive nadir rectangle missions. It ensures that images are taken from multiple sides, with the overlap required for optimal processing. Compared to the simple grid, this mission is recommended for flying closer to objects in order to capture more vertical details. Recommended in the following cases:
Plan and fly a nadir polygonal mission. Suitable for most environments that require flexible boundaries for flying or with a complex mapping shape. It ensures that images are taken with the overlap required for optimal processing. Recommended in the following cases:
Plan and fly an ellipsoid mission around objects. It ensures that the images are taken from all angles around a target point, with the overlap required for optimal processing. For high objects, flying several circular missions at different altitude is suggested. Recommended in the following cases:
Plan and fly a free flight mission (advanced users). Suitable to map more difficult objects that require more flexibility. The camera shutter is automatically triggered according to a horizontal and vertical distance interval. It requires to manually pilot the drone. Recommended in the following cases:
For more information on how to prepare a free flight mission: How to prepare and start a free flight mission. |
Hello,
Thank you for your feedback. There is no plan to implement the above-requested feature in 2020. If things change, we will post here to inform the community. It is also recommended to close the DJI Go4 app while using the Pix4Dcapture app so that there is no any communication conflicts between the apps for connecting. Please keep in mind that Pix4Dmapper can process images taken from virtually any application as long as they are of good quality and overlap. For more information: Which image acquisition app can I use with Pix4D's software?
Hello,
is it planed to support the DJI Mavic Air 2 drone, cause It would be great if the Pix4Dcapture App will work with it?
Greetings
Josef
Hello! For technical questions, please check our Community: DJI Mavic air 2 and Pix4Dcapture
Boa tarde. Nao consigo conectar ao drone para carregar a missão. Uso um smartphone Samsung s10+ e um drone DJI mavic air.
Hello Alessander,
The behavior you are describing has not been reported to us so far. I would suggest you go through all the basic checks and troubleshooting steps as it will solve most of the issues that can be encountered if properly followed.
In case the issue is not solved, I would also recommend you to go through our support article on Which image acquisition app can I use with Pix4D’s software?.
