(Android, iOS) Which type of mission to choose
Several types of mission can be selected in Pix4Dcapture. Some missions are only available on iOS and others only support certain drones on Android.
These missions were designed according the recommended image acquisition plans. For more information: 202557459.
For more information about supported hardware on the two operating systems: 203991609.
There are four autopilot missions and one manual but semi-automatic mission.
Type of mission Description Android iOS
home_screen_grid.png Grid
Plan and fly a nadir rectangle mission.
Suitable for most environments. It ensures that images are taken with the overlap required for optimal processing.
Recommended in the following cases:
  • Main interest in 2D map outputs (DSM, orthomosaic, etc.).
  • Relatively flat surface (e.g. fields, earthworks).
  • Large area.
All drones
Except:
Spark
All drones
Except:
Spark
home_sreen_double.png Double Grid
Plan and fly a two consecutive nadir rectangle missions.
It ensures that images are taken from multiple sides, with the overlap required for optimal processing. Compared to the simple grid, this mission is recommended for flying closer to objects in order to capture more vertical details.
  • Main interest in 3D model outputs (point cloud, mesh, etc.).
  • Surface with height fluctuations or objects (e.g. buildings, forest).
  • Small and medium area as the flight time is doubled.
DJI drones
Except:
P2V(+)
Spark
All drones
Except:
P2V(+)
Spark
Disco-Pro
home_screen_polygon.png Polygon
Plan and fly a nadir polygonal mission.
Suitable for most environments that require flexible boundaries for flying or with a complex mapping shape. It ensures that images are taken with the overlap required for optimal processing.
  • Large area.
  • Complex shape and constraints in the flight boundaries.
Not available yet
All drones
Except
P2V(+)
Spark
Disco-Pro
home_screen_circular.png Circular
Plan and fly an ellipsoid mission around objects.
It ensures that the images are taken from all angles around a target point, with the overlap required for optimal processing. For high objects, flying several circular missions at different altitude is suggested.
  • Isolated object (e.g. tower, pylon, building).
  • Small area.
All drones
Except
P2V(+)
Spark
All drones
Except
P2V(+)
Spark
Disco-Pro
home_screen_free.png Free Flight
Plan and fly a free flight mission (advanced users).
Suitable to map more difficult objects that require more flexibility. The camera shutter is automatically triggered according to a horizontal and vertical distance interval. It requires to manually pilot the drone.
  • Small area.
  • Complex or vertical structures (e.g. building facade, cliff, bridge, etc.
For more information on how to prepare a free flight mission: 203081219 (Android), 204261889 (iOS).
For information about the image acquisition plan: 202557459.
All drones
All drones
Except:
Bebop 2
Disco-Pro
7 out of 7 found this helpful
