(iOS) Pix4Dcapture Release 1.2
Download Pix4Dcapture for iOS via the App Store (click below for direct access):
VersionRelease dateRelease type
1.2.2 May 24, 2016 New, bug fix
1.2.1 May 8, 2016 New, bug fix
1.2.0 April 11, 2016 New
Compatible drones
  • DJI Inspire 1 and Inspire 1 Pro (I1).
  • DJI Phantom 3 Advanced (P3A).
  • DJI Phantom 3 Professional (P3P).
  • DJI Phantom 3 Standard (P3S).
  • DJI Phantom 4 (P4).
  • All other DJI drones supporting SDK 3: Not tested. Pix4D cannot guarantee that it will work with other drones.
  • Parrot Bebop 2 (B2).
Important
This version does not support DJI Phantom 2 Vision and DJI Phantom 2 Vision+ drones.
Please download the app called Pix4Dcapture P2V(+): 205708215.
Notes
  • No Free Flight Mission available for Bebop 2.
  • No Circular Mission available for DJI drones.
Version 1.2.2
What is new
  • Upgrade to DJI SDK 3.2.0 and Parrot SDK 3.9.0.
Improvements
  • Distance between the center of the grid and the home point limited to 150 m but can now be ignored in the Grid Mission settings.
  • Popup information in the General and Grid Mission settings.
  • (Bebop 2) More accurate estimation of the flight time.
  • (Bebop 2) Default size of 100 m x 100 m for the Grid and Circular Mission.
Bug fixes
  • 7-line limitation warning when designing a grid removed for all drones.
  • (Bebop 2) Fixed bug when processing on Pix4Dcloud using the generated .p4d file.
  • Various bug fixes.
Version 1.2.1
What is new
  • (DJI drones) Camera white balance settings for the Grid Mission and Free Flight Mission (automatic, sunny or cloudy).
Improvements
  • Geolocation in China.
  • Limiting distance between the center of the grid and the distance increased from 150 to 250 m.
  • Images uploaded to Pix4Dcloud in full (previously half) resolution by default: Can be changed in the general settings if needed.
  • More stable interface of the Mission Manager when synchronizing or uploading to Pix4Dcloud.
  • (Bebop 2) Upper and lower boundaries of the processing area.
Bug fixes
Version 1.2.0
What is new
  • Support of DJI Phantom 4.
  • Upgrade to SDK 3.1.0.
  • Ability to choose between a safe (stop-and-shoot) and a fast flying mode (no stops but connection with the drone is required during all the mission to trigger the camera). Note that the safe mode is selected by default.
Improvements
  • Compatibility with latest DJI firmware.
  • Ability to tweak the drone’s speed in the Grid Mission settings (fast mode only).
  • (Bebop 2) If the app crashes or if the connection is lost, an alert will be displayed when restarting the app. It suggests to either continue or stop the mission and will refocus the Map View background on the current location of the mission.
Known bugs
  • Due to some communication delays between the drone and the app, the location of camera icons on the flight tracks of the mission could be wrong. However the real geolocation of captured images remains accurate.
Bug fixes
  • (Inspire 1 Pro) X5 camera focus.
    The focus should be set to infinite with DJI GO, but the gimbal may not rotate at the beginning of the mission. Check on Camera View and do it manually if needed.
  • (Bebop 2) Image overexposure.
0 out of 0 found this helpful
Powered by Zendesk
