How to force quit an App - PIX4Dcapture
Force quit might be needed when using Pix4Dcapture:
  • (iOS) Force quit Pix4Dcapture and restart the app when changing the drone that is selected for flying.
  • Force quit any other app that could be in conflict with Pix4Dcapture when connecting to the drone.
Android
1. Open the Settings app on the Android device.
2. Scroll the list and tap Apps, Applications or Manage apps.
3. (optional) On certain devices like Samsung, tap Application Manager.
4. Scroll the list to find the app to force quit.
5. Tap FORCE STOP.
iOS
1. Double-click the Home button of the iOS device. This brings up the app switcher.
2. Scroll the apps to find the app to force quit.
3. Tap the corresponding app window and swipe it up off the screen (upwards or downwards).
4. Go back to the Home screen of the iOS device and select Pix4Dcapture.
38 out of 90 found this helpful
3 comments
  • Gerald Bader
    Good day. When using pix4d capture.The program will stop showing the progress of the drone after 9- 10 minutes of flight. The screenlocks up. The drone continues the flight and then lands, without any issues. So far. I use a Android with version 7.1.1. some of the projects are large and being able to see the progress is crucial. Thanks
  • Gerald Bader
  • Kapil (Pix4D)
    Hi Gerald,
    The picture triggering in Android devices is based on a time-lapse. Once the mission is uploaded successfully to the drone, there shouldn't be any issue for capturing the images even if the connection between the drone and remote controller freezes for a while.
    It has been reported that the application could lag during a mission. For example, drone position can be frozen for seconds. It can be related to the mobile device itself as chipset/CPU architecture may probably induce this kind of behavior. It can also be related to the Android version installed on the phone/tablet.
    You should follow the bellow workaround in case of application lagging.
    Workaround:
    • Force quit and restart Pix4Dcapture between missions.
    • Restart from scratch between missions.
    • Try another mobile device to see if the lag is still occurring.
