English
How to process Sequoia imagery - PIX4Dmapper
Imagery captured with Parrot Sequoia camera is automatically recognized by the software since the camera is in PIX4Dmapper camera database.
Important: Multispectral and RGB images of Sequoia should be processed in two different projects on PIX4Dmapper.
Processing Sequoia multispectral imagery
1. Create a new project: Step 2. Creating a Project.
2. Import all discrete band imagery (green, red, rededge and NIR imagery) from the flight. This includes the images of the calibration target.
3. Choose the Ag Multispectral processing template: Processing options.
4. The radiometric calibration target images can be automatically detected and used by the software in certain conditions. For more information: Radiometric calibration target.
5. If the radiometric calibration target data is not detected automatically, this process can still be done manually. For more information: Radiometric calibration target.
6. Select the radiometric correction options corresponding to the device configuration you used to fly. For more information: Radiometric corrections.
7. Start processing.
Processing Sequoia RGB images
2. Import all the RGB images in the same project.
3. If the flight plan is linear, ensure the Linear Rolling Shutter model is selected: How to correct for the Rolling Shutter Effect.
4. Choose the Ag RGB processing template: Processing Options Default Templates.
5. Start processing.
Processing Sequoia+ with its targetless radiometric calibration
Note: Targetless calibration with Parrot Sequoia+ is now available, starting with PIX4Dmapper 4.2.25.
The usage of a radiometric calibration target is not necessary with the targetless radiometric calibration of Parrot's Sequoia+. However, in order to use the targetless radiometric calibration of Sequoia+, the file sequoia_therm.dat is required. This file is generated automatically for each flight, is unique to each Sequoia+ and can be found for each set of images in the folder where the images are stored during the acquisition mission.
Important: The file sequoia_therm.dat, is generated by Sequoia+ and must be stored in the same folder as the original images.
To process a project with Sequoia+:
1. Create a new PIX4Dmapper project: Step 2. Creating a Project.
2. Import your multispectral images, i.e. Green, Red, Red Edge, and NIR.
3. Click Next.
4. Select the Ag Multispectral processing template: Processing Options Default Templates.
5. Select the radiometric correction according to the lighting conditions when the images were captured: Menu Process > Processing Options... > 3. DSM, Orthomosaic and Index > Index Calculator.
5.1. Camera, Sun Irradiance and Sun angle for clear skies
5.2. Camera and Sun Irradiance for overcast skies.
6. Start processing.
Information: PIX4Dcloud does not support targetless radiometric calibration at this time.
