Menu View > Volumes > Sidebar > Objects
Index > Interface > Menu View > Volumes > Sidebar  Previous  |  Next
Access: On the Menu bar, click View > Volumes to open the Volumes view. The sidebar is displayed on the left of the main window. The Volumes view is available when the point cloud and the DSM are generated.
The Objects section consists of two parts:
Action buttons
There are 3 action buttons:
    •  New volume: Allows the user to draw a new volume. For step by step instructions: How to draw a Volume.
    •  Import volume: Opens the Import Volume pop-up that allows to import volumes created previously with Pix4Dmapper or created manually for the same area of study. For step by step instructions: How to import a Volume into Volumes.
Important:
  • To import a volume created previously with Pix4Dmapper, it has to be a .shp file that contains surfaces (name_surfaces.shp) or vertices (name_vertices.shp).
  • To import a volume created with an external software, it has to be a .shp file that contains a 3D polygon (surface) or 3D vertices.
It contains the sections:
      • Navigation window: Used to search and select the file to be imported.
      • File name: Displays the name of the selected file to be imported.
      • Files of type:  Displays the possible formats accepted for the input file: Shape files (.shp) are accepted.
And the action buttons:
        • Open: Imports the selected file.
        • Cancel: Does not import the Volume and exits the pop-up.
    •  Export volume: Allows the user to select and export the volumes the following buttons appear:
      • Select: Allows the user to select All or None of the volumes to be exported. The user can also select some of the Volumes to be exported by selecting the box that appears next to the names of the volumes.
Important: At least one volume needs to be selected to be exported.
      • Cancel: Cancels the export of volumes.
      • Export: Opens the Export pop-up:
        • Navigation window: Used to search and select the directory in which the volume will be exported.
        • File name: Allows the user to select the name of the file to be exported.
        • Save as type:  Displays the possible formats accepted for the input file:
            • AutoCad DFX (.dfx).
            • ESRI Shapefiles (.shp).
            • Keyhole Markup Language (.kml).
            • Microstation DGN (.dgn).
Volume list
It contains the list of volumes added to the project and the measures for each volume.
Important: The volume is computed between the volume's base and the surface defined by the DSM generated in step 3. DSM, Orthomosaic and Index.
The volume information is displayed by clicking the volume name in the Objects layer of the sidebar.
Important: The volume information is displayed once the volume is computed. If the volume is not computed, the Compute button will appear. Clicking the Compute button will compute the volume.
      • Volume name: The name of the volume.
      • Terrain 3D Area [units2]: Area that is defined by the DSM included in the volume's base.
      • Cut Volume [units3]: Volume that is above the volume base. The volume is measured between the volume's base and the surface defined by the DSM.
      • Fill Volume [units3]: Volume that is below the volume base. The volume is measured between the volume base and the surface defined by the DSM.
      • Total Volume [units3]: Total volume, Total Volume = Cut volume + Fill volume.
Tip: For more information on the error estimation (+/-) in volume calculation: Which Base Surface is recommended for the Volume Calculation?.
When hovering over one volume, 2 action buttons appear:
  •  View/Hide: Allows to view or hide the volume from the 3D view.
  •  Delete: Allows the user to delete the volume.
When selecting a volume, 3 action buttons appear:
  •  Compute: Computes the volume selected. Appears when the volume is not computed, when there is a change in the name or in the base surface of the volume or the DSM.
  •  Copy to Clipboard: Copies the measures of the selected volume to the clipboard that can be pasted into a text editor or spreadsheet by opening the destination file and pasting.
  •  Settings: Allows the user to select the base surface settings and the display settings of the volumes. The Volume Settings pop-up appears.
It consists of two tabs:
    • Base surface Settings: Allows to select the base plane for the volume calculation. There are six different options:
      • Triangulated: Selected by default. Connects all the vertices and triangulates the volume above and below the base surface. Recommended option when the entire boundary of the stockpile is visible and the surface is relatively flat.
      • Fit Plane: Fits a plane to the vertices, so that all vertices are at the minimum distance from the base surface. Recommended option when the entire boundary of the stockpile is visible and the base surface is a hard surface, a slope or flat with the same altitude.
      • Align with Average Altitude: The base surface is parallel to the XY plane with altitude at the average altitude of all vertices.
      • Align with Lowest Point: The base surface is parallel to the XY plane with altitude at the lowest altitude of all vertices. Recommended option when part of he boundary is not visible, for example the stockpile is partially surrounded by walls.
      • Align with Highest Point: The base surface is parallel to the XY plane with altitude at the highest altitude of all vertices. Recommended option when the desired computation is the fill volume of a bunker, a pool, a pond, etc.
      • Custom Altitude [units]: The base surface is parallel to the XY plane with altitude at a custom altitude. Recommended option when the stockpile is surrounded by walls and only part or even no boundary is visible, but the altitude of the flat base surface is known.
Tip: For more information and specific cases about how to choose the base surface settings: Which Base Surface is recommended for the Volume Calculation?.
    • Display: Allows to edit the display properties for one or all the volumes.
      • Vertex Color: Color of the spheres that represent the vertices of the bases of the volumes.
      • Vertex Radius: Radius of the spheres that represent the vertices of the bases of the volumes.
      • Line Color: Color of the lines between the vertices of the bases of the volumes.
      • Line Width: Width of the lines defining the bases of the volumes.
      • Base: View/hide the bases of the volumes.
        • Color: Color of the bases of the volumes.
        • Shader: Specifies the way each triangle of the bases of the volumes is colored. The color is related to the 3D position of each triangle. There are 2 ways of coloring the triangles available:
          • Monochrome: Selected by default. The triangles are colored with a color-to-black scale depending on the angle with respect to a virtual sun positioned in the north-east at 45 degrees from the horizon. It uses the color selected above.
          • Color: The triangles are colored with an RGB scale. The color of a triangle depends on the angle with respect to 3 virtual suns with Red, Green, and Blue illumination. The color of each triangle is the combination of the light received by the 3 virtual suns. This shader gives a slope map if the model is looked at from top. It gives information about the orientation of each surface.
      • Terrain: View/hide the triangles defining the terrain. These triangles are generated using the base of the volume and the DSM and below that surface.
        • Color: Color of the triangles defining the terrain. These triangles are generated using the base surface and the points above and below that surface (this property only affects Volume objects).
        • Shader: Specifies the way each triangle defining the terrain is colored. The color is related to the 3D position of each triangle. 2 ways of coloring the triangles are available:
          • Color: The triangles are colored with a RGB scale. The color of a triangle depends on the angle with respect to 3 virtual suns with Red, Green, and Blue illumination. The color of each triangle is the combination of the light received by the 3 virtual suns. This shader gives a slope map if the model is looked at from top. It gives information about the orientation of each surface.
8 out of 13 found this helpful
12 comments
  • Billy Grace
    Hi there,
    I have made my perimeter for a stockpile I am trying to calculate the volume for. Once I finished the perimeter and right clicked to add the last vertex, the volume base was created, but the compute button is not showing....
  • Beata (Pix4D)
    Hi Billy,
    Would it be possible for you to record this behaviour or at least send us some screenshots so we could see the problem in detail?
    Best!
  • Toby Holmgren
    Hi,
    I have the same problem as Billy. 50% of the time this is an issue... Is there a way to delete the volume once this happens?
  • Beata (Pix4D)
    Hi Toby,
    Please have a look at the screenshot below:
    Could you also send me a similar image? I wonder why the Compute button is not visible for you.
  • Toby Holmgren
    The compute button is not there nor is the delete button. The only way I have found to clear it is close the program with out saving and start over.
  • Beata (Pix4D)
    Hi Toby,
    Did you try to reinstall Pix4Dmapper? Please follow How to uninstall Pix4Dmapper Desktop completely.
    Let me know how it goes.
    Best
  • Pablo Garcia
     Hola! Estoy calculando el volumen de relleno para la remediación de una cantera. Tengo el mismo problema, no aparece el botón de calcular.
    A modo informativo, el primer volumen lo calculó sin problemas, ya que la Superficie Base (para mi caso Superficie Tope) contenía pocos vértices. Luego elimine dicho Volumen y al hacer otro mas preciso respecto del borde de la superficie con una cantidad de vértices considerable dejo de aparecer el BOTÓN CALCULAR.
    A continuación dejo una captura de pantalla de lo expuesto
    Muchas Gracias por su atención.
    Agrim. Garcia
  • Avatar
    Marco (Pix4D)
    Hi,
    We have been investigating about this issue and it seems that when the geometry becomes too complex the software is not able to calculate it anymore.
    How-Pix4Dmapper-calculates-the-Volume
    It seems that there is a mismatch between the DSM and the polygon when there is too much vertices.
    For now, we cannot propose any other workaround than calculate volume on smaller Area and then sum them.
    We are really sorry about that.
    Pablo Garcia,
    Estuvimos investigando sobre este tema y parece que cuando la geometría se vuelve demasiado compleja el software ya no es capaz de calcularla.
    Parece que hay un desajuste entre el DSM y el polígono cuando hay demasiados vértices.
    Por ahora, no podemos proponer ninguna otra solución que no sea calcular el volumen en áreas más pequeñas y luego sumarlas.
    Best,
    Saludos
  • Moisés Molina
    Hi,
    I have a question, which is the best way to calculate surface area of ​​a sloping and uneven (not flat) surface ? Besides, which is the standart error ( +/- meters) that the data has for surface when I want to calculate the superficial area of a volume?
    Best,
  • Avatar
    Marco (Pix4D)
    Hi Moisés Molina,
    You might be interested into these articles:
    Error-estimation-in-volume-calculation
    Which-Base-Surface-is-recommended-for-the-Volume-Calculation
    https://community.pix4d.com/t/volume-vertices/6653
    As a general comment I would recommend you to use either triangulated or lowest point and make sure that you are using GCP if you want to have accurate results. The error will depend on the GSD of your project.
    Best
  • Marcio Pivovar
    The following information is NOT displayed for any file type :
        •  The name of the volume.
    why not ?
  • Alice (Pix4D)
    For who's gonna read your comment, see my answer to the same question here :)
