How to log in Pix4Dmapper
In order to log in to Pix4Dmapper:
1. Make sure that there is an internet connection for this procedure.
2. Double-click the Pix4D Desktop shortcut created on the desktop.
3. The window Pix4Ddesktop Login opens.
4. (optional): If a proxy server is used to connect to the internet, click Proxy... and follow these instructions: How to set up the Proxy Server Configuration.
5. Type in the Email address and Password and click Login.
Note: For the Educational Classroom license, all students should type in the same unique login and password.
6. Select:
  • Discovery Mode to activate the limited version. For more information: Pix4Ddiscovery / Discovery mode.
  • Available licenses to choose a license that is already assigned to the account.
    • Pix4Dbim
    • Pix4Dengine
    • Pix4Dmapper
    • Pix4Dmodel
    • Pix4Dfields
For more information about the Pix4D solutions: here.
7. Click OK to start using Pix4D Desktop.
5 out of 15 found this helpful
4 comments
  • Seng Kim
    How to continue process project
  • Beata (Pix4D)
    Hi Seng,
    At which step do you have a problem? Did you login to Pix4Dmapper?
    I think our video Getting started with your first Pix4Dmapper project should help you started. ;-)
    Best!
  • Stanley Jacob
    I understand there is second 10 days left for second trial of Pix4D Mapper.  After logged in its says you have a non commercial license and the software is unable to produce DEM / DSM. The option is deactivated. Processing Option number 3 is deactivated, that is DSM, Orthomosaic and Index..
    Please help?
    Stanley Jacob
  • Momtanu (Pix4D)
    Stanley, you will need to log out as it seems you are using our discovery license. Then simply launch Pix4D Desktop, login with your Pix4D account and select the trial license option to redeem your second trial license.
