Menu View > Log Output
Index > Interface > Menu View   Previous  |  Next
Access: On the Menu bar, click View > Log Output. The Log Output bar is displayed at the bottom of the main window. For information about the displayed bars: Displaying bars.
The Log Output bar displays useful information about the processing of the project. It describes the steps and substeps of processing, the actions taken, the warnings and the errors during the processing.
Important:
  • Pix4Dmapper exports the log file (project_name.log). It is stored at the output folder project_name
  • The log file displayed at the Log Output bar is cleared each time that Pix4Dmapper closes. The next time that the software will be opened, the log file will start registering the different actions from scratch.
It consists of the following:
  • Levels drop-down list: Allows to define the level of details of the log displayed on the main window.
  • Options drop-down list: Allows to set the displaying options for the log on the main window.
  • Search Engine: Allows to search for specific text / numbers in the log displayed on the main window.
  • Clear Log: Clears (deletes) the log displayed on the main window.
  • Main window: Displays the log.
  • Help: It opens Pix4Dmapper Help.
Levels
There are the following levels of details:
  • [Info]: Displays general information that is printed in the log file. The text is displayed in black.
Example: It displays the used version of Pix4Dmapper: [Info]: Version = <2.2.15>.
  • [Warning]: Displays the processing warning messages that are printed in the log file. The text is displayed in yellow.
Example: [Warning]: Some geotags were invalid and therefore removed.
  • [Error]: Displays the processing error messages that are printed in the log file. The text is displayed in red.
Example: [Error]: Failed to open file <file_directory>!.
  • [Processing]: Displays the processing steps and substeps that are printed in the log file and their status. The text is displayed in green.
Example: [Processing]: Substep Camera calibration started.
  • [UI]: Displays the actions that the user does in the User Interface. The text is displayed in blue.
Example: It displays [UI]: Open Results Folder clicked, when the user clicks the button Open Results Folder...
Options
There are the following options:
  • Full Headers: It displays the full headers (Date, Time, % RAM, % CPU).
  • Wrap Lines: It wraps the lines when the main window is too small.
Search Engine
It allows to search for specific keywords, characters of numbers. The results of the searching are displayed in the main window.
Clear Log
It clears (deletes) the log that is displayed in the main window.
Important:
  • The log file stored at the output folder project_name will not be deleted.
  • The Clear Log action can not be retrieved. Once the log is deleted from the main window, there is no way to bring it back.
Main window
It displays the log. The displayed information depends on the selected Levels and Options. If a keyword, character or number is used in the Searching Engine, the displayed log shows only the strings that contain these elements.
1 out of 10 found this helpful
14 comments
  • Holden (Pix4D)
    Hi Murat. These warnings do not necessarily mean there is a problem. Is there a specific issue you are encountering?
  • Mihaita Chiper
    Hi,
    why is it doing this?
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0218_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0219_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0220_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0221_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0222_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0223_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0224_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0225_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0226_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0227_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0228_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0229_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0230_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0231_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0232_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0233_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0234_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0235_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0236_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0237_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0238_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0239_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0240_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0241_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0242_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0243_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0244_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0245_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0246_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0247_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0248_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0249_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0250_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0251_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0252_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0253_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0254_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0255_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0256_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0257_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0258_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0259_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0260_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0261_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0262_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0263_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0264_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0265_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0266_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0267_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0268_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0269_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0270_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0271_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0272_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0273_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0274_512.jpg' not recognized as a supported file format.
    [Warning]: Warning w9020: GDAL Error <4> `C:/Users/A120Drone/Documents/pix4d/191020-rework/191020-reworked/1_initial/project_data/thumbnails/IX-12-78942_0047_IX-12-78942_0047_0275_512.jpg' not recognized as a supported file format.
    [Info]: Opening url: https://cloud.pix4d.com/knowledge-base/?topic=HELP_TOPIC_LOG_OUTPUT&version=4.4.12&lang=en_US
  • Holden (Pix4D)
    Without reviewing the entire log its difficult to know. As they are warnings it may not be critical. Is processing failing at any stage?
  • Jose Freija de Jesus Soares
    Hi there,
    can u tell me how to extract the log files from Pix4D Mapper?
  • Holden (Pix4D)
    The log file is located in the root project directory. It is a .log file that you can view in any text editor.
    Got it,
    Thank you
  • Olds College
    Hi there,
    Please help me to solve the following problem. I passed first two stages, but I am stuck at third one.
    [2020.03.11 18:44:05][ 71%RAM][ 27%CPU][Warning]: Warning w9020: GDAL Error <4> //files.win.olds/staff/ymykhaylichenko/pix4d/15-16 RGB March 11 (80 m)/1_initial/project_data/thumbnails/DJI_0995_512.jpg: No such file or directory
    [2020.03.11 18:44:05][ 71%RAM][ 27%CPU][Warning]: Warning w9020: GDAL Error <4> //files.win.olds/staff/ymykhaylichenko/pix4d/15-16 RGB March 11 (80 m)/1_initial/project_data/thumbnails/DJI_0996_512.jpg: No such file or directory
    [2020.03.11 18:44:05][ 71%RAM][ 27%CPU][Warning]: Warning w9020: GDAL Error <4> //files.win.olds/staff/ymykhaylichenko/pix4d/15-16 RGB March 11 (80 m)/1_initial/project_data/thumbnails/DJI_0997_512.jpg: No such file or directory
    [2020.03.11 18:44:05][ 71%RAM][ 27%CPU][Warning]: Warning w9020: GDAL Error <4> //files.win.olds/staff/ymykhaylichenko/pix4d/15-16 RGB March 11 (80 m)/1_initial/project_data/thumbnails/DJI_0998_512.jpg: No such file or directory
    [2020.03.11 18:44:05][ 71%RAM][ 27%CPU][Warning]: Warning w9020: GDAL Error <4> //files.win.olds/staff/ymykhaylichenko/pix4d/15-16 RGB March 11 (80 m)/1_initial/project_data/thumbnails/DJI_0999_512.jpg: No such file or directory
    [2020.03.11 18:45:20][ 73%RAM][ 19%CPU][UI]: Processing Options clicked.
    [2020.03.11 18:48:07][ 73%RAM][ 24%CPU][UI]: Processing Start clicked.
    [2020.03.11 18:48:09][ 73%RAM][ 24%CPU][Processing]: Step3Running
    [2020.03.11 18:48:11][ 73%RAM][ 32%CPU][Processing]: Substep Ortho load pcl started.
    [2020.03.11 18:48:11][ 73%RAM][ 32%CPU][Processing]: Load point cloud
    [2020.03.11 18:48:13][ 73%RAM][ 33%CPU][Error]: Loading PCL <//files.win.olds/staff/ymykhaylichenko/pix4d/15-16 RGB March 11 (80 m)/2_densification/project_data/15-16 RGB March 11 (80 m)_group1_densified_point_cloud_part_1.p4b> failed
    [2020.03.11 18:48:13][ 73%RAM][ 33%CPU][Error]: Load point cloud: failed to load the point cloud!
    [2020.03.11 18:48:13][ 73%RAM][ 33%CPU][Error]: Load point cloud failed!
    [2020.03.11 18:48:13][ 73%RAM][ 33%CPU][Error]: >>>Load point cloud<<< failed with error (failed to run a step!)!
    [2020.03.11 18:48:13][ 73%RAM][ 33%CPU][Processing]: Substep Ortho load pcl finished.
    [2020.03.11 18:48:13][ 73%RAM][ 19%CPU][Processing]: Step2Done
  • Beata (Pix4D)
    Hi,
    The issue you are experiencing is a common problem while your machine does not have enough RAM for the processing.
    Please reduce resources and shown in the image below and reprocess Step 3.
    If it will not solve the problem, please follow our instructions from this article and reduce the Processing Options for Step 2.
    Let me know if you need anything else.
    Regards
  • Simbarashe Kwashiwa
    Good day
    If there was a loss of power, how do i continue from where i left when the power comes back whilst was working in "read-only/processing" mode
  • Kapil (Pix4D)
    Hi Simbarashe,
    You can't continue from where you left. However, you don't have to repeat the step that is already processed before power loss. For example, if you had a power loss during step 2, then you have to only process step 2 and step 3.
    Regards,
    Edited by Kapil (Pix4D)
    Good day
    How do I command the system to start at step 2 and then step 3 without starting at step 1?
    Regards
  • Beata (Pix4D)
    Hi Simbarashe Kwashiwa,
    You cannot process Step 2 or 3 without processing Step 1.
    If Step 1 is processed and you don't want to process it again, please uncheck the box of Step 1 and mark Step 2 and 3 as in the example below.
    Regards
  • marion previtali
    Hi,
    Can you help me to understand and solve my problems with this processing ? Lots of [error] message particulary in step 3.
    Where can i send you the log file ? I made a wetransfert https://we.tl/t-2BGCV9QU7F .
    Thanks for your help
  • Kapil (Pix4D)
    Hi Marion,
    As you have valid support and updates, you can directly contact the support through email. You can use the below link to contact support.
    https://support.pix4d.com/hc/en-us/requests/new?
    Thanks,
