(Android) Pix4Dcapture Release 2.0
Download the Android App here or via Google play (click below for direct access):
Get it on Google Play
VersionRelease dateRelease type
2.0.8 December 8, 2015 Bug fix release
2.0.7 November 4, 2015 Bug fix release
2.0.6 November 4, 2015 New release
Version 2.0.8
Bug fixes
  • Updated DJI SDK to 2.4.1.
Known bugs
  • (P3A, P3P and I1) Synchronization of the images
    • At the end of the mission the images are not synchronized properly. Workaround:
      1. Disable the Sync automatically when mission ends option in the settings. For more information: 203873435.
      2. Transfer the images from the drone's SD card to the computer.
      3. Create a new Pix4Dmapper project and process the images locally. For more information: 202557369.
  • (P3A, P3P and I1) Connection problem
    • With some devices and Android versions, the connection is failing and the application is requesting to connect by WiFi.
Version 2.0.7
Bug fixes
  • Various bug fixes.
Known bugs
  • (I1) Low battery level in the takeoff checklist
    • The battery level is not recognized correctly by the SDK for the Inspire 1. Workaround:
      1. Enable the advanced mode: Go to Settings > Advanced settings and enable the advanced mode.
      2. In the take off checklist, ignore the battery level check by pressing on the check.
Version 2.0.6
What is new
  • Support for:
    • Inspire 1
    • Phantom 3 Professional
    • Phantom 3 Advanced
  • New Mission Manager
    Allows the upload of multiple missions simultaneously
  • Select speed
    Adjust the speed of the drone for the Grid Mission
  • Advanced mode
    Allows to ignore some safety checks
Improvements
  • Improved User Interface for Grid Mission Map View
    A new interface to allow selecting the speed, angle and the overlap directly in the Map View.
  • New Altitude limits
    It is possible to set the Grid Mission altitude between 10 and 150 meters.
Bug fixes
  • Various bug fixes
Known bugs
0 out of 0 found this helpful
Powered by Zendesk
