What is... (a densified point cloud? an orthomosaic? etc.)
What is a densified point cloud?
The densified point cloud is a set of 3D points that reconstruct the model. The X,Y,Z position and the color information is stored for each point of the densified point cloud.
The densified point cloud is computed based on the automatic tie points (ATPs) of step 1. Initial Processing and it provides a very accurate background for distance, surface and volume measurements.
What is a 3D textured mesh?
The 3D textured mesh is a representation of the shape of the model that consists of vertices, edges, faces and the texture from the images that is projected on it.
It is useful to present and visualize the model, share it and upload it to online platforms such as Sketchfab. It is intended to look nice more than to be accurate, so it is not recommended to use it for measurements.
What is an LOD mesh?
The LOD (Level Of Details) mesh is a representation of the 3D textured mesh that contains multiple levels of detail, decreasing the complexity of the model as it is divided into more levels.
The LOD mesh is useful for visualization on the web and from different types of devices, such as desktop PCs, tablets, smartphones, when fast loading is needed. It is the ideal output for smooth and efficient navigation on online viewers.
Note: The LOD mesh cannot be visualized in Pix4D Desktop. It can be exported and visualized in other software: Skyline TerraBuilder, SuperMap or in web viewers, such as ArcGIS Online.
For step-by-step instructions about how to export the LOD mesh: How to export the Triangle Mesh .
What is a polyline?
A polyline is a continuous line composed of one or more sub-lines. It is created by specifying the vertices of each line.
Pix4D gives the ability to draw 3D polylines, where each vertex has three coordinates. Polylines are typically used to measure distances in the model.
For step-by-step instructions about how to draw a new polyline with the rayCloud: 202560309.
For more information about projected 2D length and terrain 3D length of polylines: Projected 2D length and terrain 3D length of polylines.
What is an orthomosaic?
The orthomosaic is a 2D map. Each point contains X, Y, and color information. The orthomosaic has a uniform scale and can be used for 2D measurements (distance, surface). It corrects the following problems of the input images:
  • The perspective of the camera.
  • Different scale based on the distance that each point of the object/ground has from the camera.
The orthomosaic generation is different from photo stitching. For more information: Photo stitching vs orthomosaic generation.
What is a reflectance map?
The reflectance map is mainly used when the input is multispectral/thermal imagery. For more information about the reflectance map vs orthomosaic: Reflectance map vs orthomosaic.
For each band, Pix4D produces one reflectance map. The goal is to properly assess the reflectance for a particular feature based on the pixel value in the images. This pixel value is influenced by many factors, including but not limited to:
  • Incoming light.
  • ISO.
  • Aperture.
  • Shutter speed.
  • Sensor response and optical system.
  • Vignetting.
Pix4Dmapper, therefore, uses the camera positions and the reconstructed model to take these different factors into account and produce an accurate reflectance map. To obtain representative results, it is important to have the right equipment. For Pix4D's recommendations concerning camera requirements: Camera Requirements for Precision Agriculture.
Note: In order to produce accurate reflectance maps, multispectral imagery can be radiometrically calibrated and corrected by Pix4D. For more information: Radiometric calibration target, Radiometric corrections.
What is a DSM?
The digital surface model (DSM) is a 2.5 D model of the mapped area. It can be exported as two different types of files:
  • Raster GeoTIFF.
  • Point cloud (.xyz, .las, .laz).
Each pixel of the raster geotiff file and each point of the point cloud contain (X,Y,Z) information. They do not contain color information.
For each (X,Y) position, the DSM has only 1 Z value (the altitude of the highest point for this (X,Y) position). This is why it is considered to be a 2.5D model.
Example: The edge E in the following image has 2 vertices with different altitude values (Z2>Z1). In the DSM this edge will only be shown as the point (X,Y,Z2).
House - Side view House - Top view - DSM
For more information about how to visualize the raster DSM file: How to visualize the GeoTIFF DSM File.
What is a DTM?
Video: Watch the instructional video related to DTM: here.
The digital terrain model (DTM) is a 2.5 D model of the mapped area after filtering out the objects, like buildings. It can be exported in GeoTIFF raster file format.
Each pixel of the raster file contains (X,Y,Z) information but they do not contain color information.
DTM of the city center of Lausanne DSM of the city center of Lausanne
What is an index map?
Pix4D generates several well-known indices such as NDVI as well as custom indices. For more information: How to work with Indices - Formulas in the Index Calculator.
Each index is associated with an index map. For each pixel on this map, the value of the pixel is derived from the associated reflectance maps.
Example: Consider the custom index with formula (RED NIR) / (GREEN + 1) and a fixed pixel. Say the associated pixel in the reflectance maps has the following values:
  • Pixel value in the red reflectance map: 0.4.
  • Pixel value in the NIR reflectance map: 0.6.
  • Pixel value in the green reflectance map: 0.1.
The value of this pixel in the index map is (0.4 0.6) / (0.1 + 1) = 0.18.
For more information about how to generate index maps: How to generate an Index Map / Index Grid in the Index Calculator.
33 out of 48 found this helpful
20 comments
  • Dominic Fillion
    I want to import a point cloud on the cloud, but there are 4 files (part 1 to 4). But when I am on the cloud, there is only the option to upload one part, so the project is 1/4 on the 3D, is there a way to import the 4 part ??
  • Alice (Pix4D)
    Hi Dominic, to merge the point cloud files that have been generated locally, check this other Support article https://support.pix4d.com/hc/en-us/articles/206364863-How-to-merge-the-Tiles-of-the-Point-Cloud
  • berry njr
    orthomosaic not working
  • Avatar
    Momtanu (Pix4D)
    Berry,
    We would need more details to help. Can you describe what is happening? Are you getting any error? A screenshot would be good to have.
  • Geopartner Geopartner
    Hello, how can I separate orthomosaic into pieces or export it to different files (after transformation I have file that is about 6gb), so I can upload them to CAD program separately?
  • Avatar
    Momtanu (Pix4D)
    Hi, It seems you are having issues importing a big tiff file to CAD. You can have a look here: https://community.pix4d.com/t/very-large-pix4d-orthomosaic-not-importing-in-autodesk-civil-3d/7476/2. The smaller tiles should be automatically generated in every project. I would recommend doublechecking the …\3_dsm_ortho\2_mosaic\tiles 1  folder and loading each individual tile in AutoCAD.
    Thanks a lot, have a nice day
  • Dominic Fillion
    Is there a way to clean a 3D roof by modifying the point could on the desktop to be able to measure what is under a roof ? Thank you.
  • Avatar
    Teodora (Pix4D)
    Hi Dominic,
    Pix4Dmapper provides an editing tool, which you can use to improve the point cloud, remove noise or reassign point cloud to different classes. More details can be found in this article: https://support.pix4d.com/hc/en-us/articles/202560499-How-to-edit-the-point-cloud-in-the-rayCloud
    Best,
    Teodora
  • joice silva
    Não esta sendo processado o orthomosaico no pix4Dcloud
  • joice silva
    Alguem pode me ajudar ?
  • Marco Paccagnella
    Hola Joice, por favor describe el problema con más detallas en nuestro Foro.
  • Crockett Walter
    Is it possible to export a single 5 band tiff as a reflectance map from Pix4D Mapper? I am struggling to find this in the documentation and export files.
  • Avatar
    Momtanu (Pix4D)
    Crockett, Unfortunately, that is not possible. You will need to use the single band reflectance maps and then make a 5 band composite in QGIS or ArcGIS.
  • Cody Purchase
    Hello, I am having difficulty uploading a orthomosaic into a cloud project. The DSM is uploading and showing in the right spot but the Orthomosaic is not showing up at all. I have processed locally and I'm pretty sure I've used the correct coordinate system.
  • Avatar
    Momtanu (Pix4D)
    This error is expected for outputs having a significant size and/or a complex geometry. In this case, the tiling process failed, meaning that the generated 2D output could not be split into smaller web maps (tiles) for several zoom levels and, for this reason, the output cannot be displayed. You can reduce the resolution in QGIS or Pix4D and upload again.
  • Niek Broekhoven
    I was wondering is the orthomosaic included in the free trial version?
    I've downloaded Pix4Ddiscovery and I can only merge rasters to pointclouds but I need to merge them to a new raster
    If this is not possible with the version I got and the trial, is there a possibility that I could use this on free base?
    Greetings, Niek
    Edited by Niek Broekhoven
  • Avatar
    Momtanu (Pix4D)
    The trial version has all the features. Pix4D discovery is our free version and some features are disabled. If you do not have a trial and want one, I would recommend reaching out to the sales team.
  • Rod Moore
    I left my computer on to process step 3 overnight. When I woke up the computer had restarted. After logging into Pix4D I see that Step 3 is now green in the processing workflow but I don't see my orthomosiac in the folder. Does this mean that Step 3 didn't really finish?
  • Avatar
    Momtanu (Pix4D)
    Can you check the processing options to see if geotiff was enabled?
    If not, the orthomosaic will not be generated. In that case, you have to enable the outputs you need, and process step 3 again.
