(iOS) Pix4Dcapture P2V(+) Release 0.4
Download Pix4Dcapture for iOS via the App Store (click below for direct access):
VersionRelease dateRelease type
0.4.0 August 06, 2015 New beta
Compatible drones
  • DJI Phantom 2 Vision (P2V).
  • DJI Phantom 2 Vision+ (P2V+).
Important
This version called Pix4Dcapture P2V(+), does not support DJI Inspire 1 (Pro), Phantom 3 (Standard, Advanced, Professional), Phantom 4 and Parrot Bebop 2 drones. Please see the Release Notes of the other app called Pix4Dcapture that can be downloaded here: App Store.
Version 0.4.0
What is new
  • New Interface for Grid Mission Map View
    A new interface for the Map View allows to position, rotate and resize the grid and get an immediate response for the mission directly on the map view.
  • Select flight altitude
    Select the flight altitude for the Grid Mission directly in the Map View.
  • Select overlap
    Select the overlap between the images for the Grid Mission in the Settings.
Improvements
  • New interface for Free Flight Mission Map View
    A new interface allows to directly set the minimum horizontal and vertical distance between two images in the Map View.
Bug fixes
  • Various bug fixes.
  • Fix bug where it was impossible to upload one mission after the other.
0 out of 0 found this helpful
Powered by Zendesk
