Pix4Dmapper 2.0 (beta) Technical Release Notes
This is the beta release of the new Pix4Dmapper 2.0. Get a preview of the new features and help us improve the product by reporting any issues to support@pix4d.com
Disclaimer: the documentation is not yet ready for 2.0 Beta, and we do not recommend using the Beta for production work. No support is provided for the beta.
VersionRelease dateRelease type
2.0.67 July 31, 2015 Beta bug fix
2.0.64 July 28, 2015 Beta bug fix
2.0.58 July 15, 2015 Beta bug fix
2.0.53 July 6, 2015 Beta bug fix
2.0.51 July 3, 2015 Beta bug fix
2.0.50 July 2, 2015 First beta
Version 2.0.67
Bug fixes
  • User Interface
    • Various bug fixes and improvements in the User Interface, mainly in the Processing Options window and Select Coordinate System window.
  • Project Management
    • Fix bug where a .p4d file could not be opened in some cases when the image location has changed.
    • Fix bug where wrong camera model was selected when opening a .p4d project file with minimum format.
    • Fix bug where a project with images of a different resolution than the camera model could be loaded and processed. This caused processing failure.
  • Processing
    • Fix crashes when processing Airinov multiSPEC 4C images.
  • Mosaic Editor
    • Fix bug where the Mosaic View was not correctly refreshed after changing some visualization properties.
    • Fix bug where the visualization settings are not saved when closing the Mosaic Editor.
Improvements
  • Inputs
    • Improved detection of image geolocation files with wrong format.
  • Index Calculator
    • Improve Reflectance Map and NDVI Index Map generation to remove artifacts for projects with Airinov multiSPEC 4C images.
Version 2.0.64
Bug fixes
  • GCPs/Manual Tie Points Manager
    • Fix bug where exporting GCP/MTP image marks was not always possible.
    • Fix bug where GCPs/MTPs could be removed while processing.
  • Processing Options
    • Fix bug where Orthomosaic or Densification Area disappeared after changing template.
  • Outputs
    • Fix bug where KML files could not be opened in Google Earth anymore.
    • Fix bug where the contour lines file name for contour lines in feet was wrong.
    • Fix bug where the coordinate system unit was not correctly stored in LAS files for projects with Arbitrary output coordinate system in feet.
  • Quality Report
    • Fix bug where the Relative Geolocation Variance table was not correctly updated when regenerating the Quality Report after changing the image geolocation accuracy.
  • rayCloud
    • Fix bug where when marking GCPs/MTPs the images were not centered on the correct location. This bug also randomly made the software crash.
    • Fix bug where in some cases the Clipping Box was not correctly initialized and displayed far away from the point cloud.
  • Mosaic Editor
    • Fix bug where the Mosaic Editor was only exporting the transparent Orthomosaic and not the non-transparent Orthomosaic.
    • Fix bug where artifacts were visible in the Mosaic at tiles borders.
  • Index Calculator
    • Fix thermal color palette to use the correct colors.
    • Fix bug where indices from the software database could be edited.
    • Fix bug where artifacts were visible in the Reflectance Map at tiles borders.
Improvements
  • User Interface
    • Various User Interface improvements.
    • New interface to use and manage Processing Options Templates.
  • Quality Report
    • Don't display the Geolocation Details if the external camera parameters are not optimized (i.e. if the image geolocation is not optimized).
  • Index Calculator
    • Import regions from polygon shapefile.
Version 2.0.58
Bug fixes
  • Project download
    • Fix bug where projects with special characters could not be downloaded.
    • Fix bug where projects uploaded from the software were not downloaded correctly.
  • Project creation using a video
    • Fix bug where the wrong number of images were extracted for videos other than .mp4 videos from the GoPro.
  • Inputs
    • Fix bug where images with altitude = 0 where not recognized as being geolocated.
  • Coordinate Systems
    • Fix bug where changing the Geoid Height Above Ellipsoid was not taken into account.
  • Processing
    • Fix bug where project with no image geolocation, with MTPs and with arbitrary output coordinate system could not be processed.
    • Fix bug where processing failed when using non marked GCPs that do not lie on the same area than the images.
  • Quality Report
    • Fix bug where the project area displayed in the Quality Report was wrong.
  • Maps View
    • Fix bug where software crashed when re-drawing the orthomosaic or densification area in the Maps View.
  • rayCloud
    • Fix bug where depending the coordinate system used, MTPs where not at the correct position anymore when re-opening a project. This has as consequence that measurement objects (polyline, surface, volume) also appear at the wrong position.
    • Fix bug where MTP marks in uncalibrated images could not be removed.
  • Mosaic Editor
    • Fix bug where mosaic editor was crashing when changing a region from ortho to planar projection.
    • Fix bug where a region drawn outside the orthmosaic area could not be deleted.
  • Command line
    • Fix bug so that all options except -v, -h, --close-gui work with or without the -c option.
Improvements
    • Improved user interface for video frames extraction.
    • Allow to enable/disable site calibration for initial processing.
  • Processing
    • Improve alternative processing pipeline so that for datasets that are not good enough to calibrate processing fails instead of never ending.
    • Improved point cloud optimization.
  • Command line
    • New option (--disable-cs-guess) that allows to select the Output Coordinate System from the UI when opening a .p4d file generated through the command line.
Version 2.0.53
Known bugs
  • Index Calculator
    • Crashes when generating the Reflectance Map.
    • Crashes in the Index Map export.
  • Processing
    • Sometimes the matching phase at step 1 enters an infinite loop and never ends.
    • Sometimes crashes after a step completes.
  • rayCloud
    • Nothing is displayed in the rayCloud for project in arbitrary coordinates with densification areas in other coordinate system. This happens when the output coordinate system is changed after having defined the densification area.
  • Command line
    • Command line will launch graphic interface even with -c.
Improvements
  • Index Calculator
    • Improved Reflectance and Index Map generation that reduces artifacts.
Bug fixes
  • Processing
    • Fix bug where the externals camera parameters in the file params/*_calibrated_external_camera_parameters.txt were not saved in output coordinate system.
  • Project management
    • Fix bug where results were not read when moving the project and its results to another directory.
Version 2.0.51
Known bugs
  • Index Calculator
  • Processing
  • rayCloud
    • Nothing is displayed in the rayCloud for project in arbitrary coordinates with densification areas in other coordinate system. This happens when the output coordinate system is changed after having define the densification area.
  • Command line
Bug fixes
  • Processing
    • Fix bug where the initial processing option "Geometrically Verified Matching" was always used, which slowed down initial processing.
  • Maps View
    • Fix bug where the Orthomosaic Area could not be removed from the Maps View.
  • Mosaic Editor
    • Fix crash that happened when drawing a region outside the mosaic.
    • Fix bug where loading a mosaic processed with version 1.4 or older failed.
Version 2.0.50 (BETA)
Known bugs
  • Index Calculator
  • Processing
  • rayCloud
  • Mosaic Editor
    • Cannot load a mosaic processed with version 1.4 or older.
  • Command line
What is new
  • Generate an orthomosaic from any plane
    • Define an orthoplane in the rayCloud and use it to generate an orthomosaic. This allows to generate orthomosaics for building facades, bridge piles, etc.
    • Define surfaces on facades and use them to generate the DSM. This allows to flatten the point cloud and generate orthomosaics for flat surfaces more accurately.
  • Scale and orient the 3D model
    Define the scale and orientation of the 3D reconstruction by creating scale and orientation constraints in the rayCloud. This is useful when having projects with unprecise or no image geolocation and when using no GCPs.
  • Redesigned Mosaic Editor
    The redesigned Mosaic Editor allows to edit the mosaic generated at step 3. The changes done to the mosaic can be directly visualized in the Mosaic Editor before saving them.
  • Create 3D models and maps from video files
    Create a new project using a video file.
  • Processing Options Templates
    Processing options templates can be used to initialize processing options according to the type of images to be processed and which outputs are desired.
  • Processing options window new layout
    A new layout for the processing options allows to easier find the different options for step 1, 2 and 3. Advanced options are displayable only on demand for advanced users.
  • More robust initial processing
    Increase the targeted number of extracted keypoints to reconstruct datasets with low image content or low overlap (e.g. fields). Decrease the targeted number of extracted keypoints to speed up processing for projects with very high overlap or for very large images with a lot of image content.
  • Initial processing calibration method based on image geolocation
    This new processing method allows to process datasets with very accurate image position and orientation. It uses the image geolocation to calibrate the images, i.e. to optimize the internal camera parameters. Processing is therefore faster.
  • New DSM generation method
    New DSM generation method (Inverse Distance Weighting) which improves the orthomosaic quality. The effect is mostly visible on building edges which appear sharper.
  • Download projects from the Pix4D Cloud account
    Download projects from your Pix4D Cloud account to process them on your computer.
  • Redesigned command line
    In order to change the processing options in the command line a processing options template file has to be used. No other command line option allows to change the processing options.
Improvements
  • Concepts and names
    • The Aerial, Alternative, Oblique Processing Type has been replaced by processing options templates used to initialize the processing options.
    • The Full and Rapid processing modes have been removed. It has been replaced by processing options templates, where for each template a Rapid/Low Res template exists, that provides fast low resolution results.
  • User interface
    Various improvements in the user interface such as:
    • New icons for part of the software.
    • Text section in the toolbar.
    • Integrated tutorials.
  • Installer and updates
    • Display the new version number in the automatic update window.
    • Display the version number in the installer wizard on the first page.
  • New project creation
    • Improved new project creation workflow. The user can easier select the accuracy of the image geolocation and can already set the output coordinate system. He can choose the processing options template to initialize the processing options according to the type of dataset to process and the desired type of output.
  • GCP/Manual Tie Point Manager
    • Import/export GCP/MTP image marks from 2 new formats:
      • Pix4D marks file (.csv)
      • XML Structure (.xml)
  • Coordinate systems
    • Additional support for vertical coordinate systems:
      • Allow conversion between MSL and WGS84 ellipsoid
      • Do not convert altitude
    • Improved user interface that displays either general or advanced options to select the coordinate system.
    • Automatically detect coordinate system when possible.
  • Quality Report
    • Display time spent for processing for step 1 (without report generation), step 2, and step 3.
    • Display all processing options used.
  • Outputs
    • Export the image position of all the automatic tie points to a .txt file.
    • Save undistorted images for fisheye cameras.
    • Export the 3D Texture Mesh as FBX or AutoCAD DXF.
  • rayCloud
    • More navigation modes available to navigate in the 3D model. Choose between standard, trackball and first person navigation.
    • Display initial image and GCP position in output coordinate system in the right sidebar.
    • Display Check Points in orange to distinguish from GCPs.
  • Index Calculator
    • Import/export region boundaries from shapefile.
    • Define a prescription for all Regions of a given Class at once.
    • More color maps available for the index classes.
    • Export Colored Index Map as KML and PNG.
  • Command line
    • The Quality Report is now generated as .pdf when processing using the command line.
    • Allow to login/logout from the software using the command line.
0 out of 0 found this helpful
