Index > Interface > Menu Process | Previous | Next |
The section about templates allows to:
- Load (select) a template.
- Save a custom template.
- Visualize the description of a template (Manage Templates).
- Edit the name and description of a custom template (Manage Templates).
- Delete a custom template (Manage Templates).
- Import templates from the support site (Manage Templates).
It contains:
- Current Options: Displays the selected processing options template.
Load Template: Allows to select a processing options template.
Save Template: Displays two options:
- Update "Template" with Current Options: Allows to overwrite the processing options template with the new selected options. Available when a Personal template is selected and some options have been changed.
- Create New Template with Current Options...: Allows to save the selected processing options as new Personal processing options template. Opens the Create New Template pop-up which allows to enter a Name and a Description for the new template:
Manage Templates...: The pop-up Templates Manager appears:
It contains two sections:
- List of existing processing options templates.
- Description of the selected processing options template regarding the:
- Image acquisition: Recommended image acquisition type for applying the template; the blue color refers to the acquisition plan and the yellow color refers to the terrain or object type.
Outputs Quality/Reliability: The scale ranges from Low to High to differentiate the quality and reliability of the results between full and rapid/low resolution processing ; high reliability indicates the higher resolution that can be achieved for the specific dataset with the specific processing options selected in the template.
- Processing Speed: The scale ranges from Slow to Fast to differentiate the completion time between the full and rapid/low resolution processing.
- Outputs Generated: List of images of the generated outputs.
- Application Examples: List of common applications for which the template should be used.
And the buttons:
- New: Creates a new processing options template in the Personal section with the selected processing options.
- Duplicate: Duplicates an existing processing options template with another name.
- Remove: Deletes a processing options template.
- Check box Import/Export: displays the buttons:
- Import...: Allows to import a template (.tmpl files created with Pix4Dmapper).
- Export...: Allows to export a template as a .tmpl file.
Folder...: Opens the folder where the user processing options template are saved.
- OK: Confirms the changes.
- Cancel: Does not save the changes.
