Here is a description of the available processing templates:
Processing Options Template | Characteristics |
Standard | |
3D Maps | Generates a 3D map (point cloud, 3D textured mesh), as well as a DSM and an orthomosaic. Image acquisition: nadir or oblique flight. Typical input: aerial images acquired using a grid flight plan with high overlap. Outputs quality/reliability: high. Processing speed: slow. Application examples: quarries, cadaster, etc. |
3D Models | Generates a 3D model (point cloud, 3D textured mesh). Image acquisition: oblique flight or terrestrial. Typical input: any images with high overlap. Outputs quality/reliability: high. Processing speed: slow. Application examples: 3D models of buildings, objects, ground imagery, indoor imagery, inspection, etc. |
Ag Multispectral | Generates reflectance, index (such as NDVI), classification and application maps. Image acquisition: nadir flight with a multispectral camera. Typical input: images taken with a multispectral camera (Sequoia, Micasense RedEdge, Multispec 4C, etc). Outputs quality/reliability: high. Processing speed: slow. Application examples: precision agriculture. |
Rapid | |
3D Maps - Rapid/Low Res | Faster processing of the 3D Maps template for assessing the quality of the acquired dataset. Outputs quality/reliability: low. Processing speed: fast. |
3D Models - Rapid/Low Res | Faster processing of the 3D Models template for assessing the quality of the acquired dataset. Output quality/reliability: low. Processing speed: fast. |
Ag Modified Camera - Rapid/Low Res | Faster processing of the Ag Modified Camera template for assessing the quality of the acquired dataset. Output quality/reliability: low. Processing speed: fast. |
Ag RGB - Rapid/Low Res | Faster processing of the Ag RGB template for assessing the quality of the acquired dataset. Output quality/reliability: low. Processing speed: fast. |
Advanced | |
Ag Modified Camera | Generates reflectance, index (such as NDVI), classification and application maps. Image acquisition: nadir flight with a modified RGB camera. Typical input: images taken with a modified RGB camera. Outputs quality/reliability: high. Processing speed: slow. Application examples: precision agriculture. |
Ag RGB | Generates an orthomosaic for precision agriculture. Image acquisition: nadir flight over flat terrain with an RGB camera. Typical input: images taken with an RGB camera for agriculture (Sequoia RGB). Outputs quality/reliability: high. Processing speed: average. Application examples: digital scouting, report claiming for precision agriculture. |
Thermal Camera | Generates a thermal reflectance map. Image acquisition: nadir flight with a thermal camera. Typical input: images taken with a thermal camera (such as Tau 2 based cameras: FLIR Vue Pro, FLIR XT). Output quality/reliability: high. Processing speed: slow. |
ThermoMAP Camera | Generates a thermal reflectance map. Image acquisition: nadir flight with a thermoMAP camera. Typical input: images taken with a thermoMAP camera. Output quality/reliability: high. Processing speed: slow. |
