This article describes the format of the .tmpl template file. This could be useful when there is a need to create a template file to automate processing using the command line.
Note: It is recommended to use the user interface as much as possible to create templates and to export them to a file.
.tmpl file format
The .tmpl file contains information about the processing options and which processing steps to run. The .tmpl file is written in XML format and has a formal definition by means of a XSD (XML Schema Document) file. The XSD file can be found in the installation directory in "resources/xsd/templates_*.xsd".
The name of the .tmpl file defines the template name that will be displayed in the software's User Interface.
The .tmpl file has the following structure
.tmpl 3.3 format summary |
<? xml version = "1.0" encoding = "UTF-8" ?>
< pix4dtmpl>
< information>
<info>
<!--Contains user information about the template-->
</info>
<version>
<!--Contains the software version defining the template format-->
</version>
</ information>
initial >
initial >
</ pix4dtmpl>
.tmpl XML tags
The section below lists the XML tags used for each processing options.
1. Initial Processing
Processing options for step 1. Initial Processing. For more information: Menu Process > Processing Options... > 1. Initial Processing > General.
Run Step |
Option |
XML Tag |
Value Type and Range |
Example |
Run step 1. Initial Processing |
runStep |
Defines if step 1 should be run or not. Value can be:
- true: run step 1
- false: do not run step 1
<runStep>true</runStep> |
General |
Option |
XML Tag |
Example |
Keypoints Image Scale |
Keypoint Image Scale |
keypointsImageScale |
Defines how the image scale for keypoint extraction is chosen. Value is given by a string. It can be:
- Full: for Full
- Rapid: for Rapid
- Custom: for Custom
<keypointsImageScale>Full</keypointsImageScale> |
Image Scale |
imageScale |
Used only if keypointsImageScale = Custom
Defines the image scale used for keypoint extraction.
- If Keypoint Image Scale is Full or Rapid: the Image Scale value is automatically chosen.
- If Keypoint Image Scale is Custom: the value can be:
- 0.125: for 1/8 (eighth image size)
- 0.25: for 1/4 (quarter image size)
- 0.5: for 1/2 (half image size)
- 1: for 1 (original image size)
- 2: for 2 (double image size)
<imageScale>1</imageScale> |
Quality Report |
Generate Orthomosaic Preview in Quality Report |
generateOrthoInReport |
Defines if the orthomosaic preview should be generated for the Quality Report or not. Value can be:
- true: generate orthomosaic preview
- false: do not generate orthomosaic preview
<generateOrthoInReport>true</generateOrthoInReport> |
Matching |
Option |
XML Tag |
Example |
Matching Image Pairs |
matchStrategy |
Defines how to select the image pairs to match together. Value is given by a string. It can be:
- AutoAerial: for Aerial Grid or Corridor
- AutoOblique: for Free Flight or Terrestrial
<matchStrategy>AutoAerial</matchStrategy> |
Use Capture Time |
matchTimeNbNeighbours |
Used only if matchStrategy = Custom
Defines if the images pair should be matched according to capture time. Value can be:
- 0: Do not use capture time
- a positive integer n such that 0 ≤ n ≤ 50: Number of Successive Neighboring Images
<matchTimeNbNeighbours>2</matchTimeNbNeighbours> |
Use Triangulation of Image Geolocation |
matchUseTriangulation |
Defines if the image pairs should be matched by using a triangulation of the image geolocation. Value can be:
- true: use triangulation
- false: do not use triangulation
<matchUseTriangulation>true</matchUseTriangulation> |
Use Distance |
matchRelativeDistanceImages |
Defines if the image pairs should be matched according to the distance between them. Value can be:
- a decimal number < 0: use Relative Distance Between Consecutive Images
- a decimal number > 0: use absolute Distance Between Consecutive Images
- a decimal number = 0: do not use distance
<matchRelativeDistanceImages>-1.5</matchRelativeDistanceImages> |
Use Image Similarity |
matchImageSimilarityMaxPairs |
Defines if the image pairs should be matched using image similarity. Value can be:
- 0: Do not use image similarity
- a positive integer n such that 0 ≤ n ≤ 100: Maximum Number of Pairs for Each Image Based on Similarity
<matchImageSimilarityMaxPairs>2</matchImageSimilarityMaxPairs> |
Use MTPs |
matchMtpMaxImagePair |
Defines if the image pairs should be matched using Manual Tie Points. Value can be:
- 0: Do not use MTPs
- a positive integer n such that 1 ≤ n ≤ 50: Maximum Number of Image Pairs per MTP
<matchMtpMaxImagePair>50</matchMtpMaxImagePair> |
Use Time for Multiple Cameras |
matchTimeMultiCamera |
Defines if time should be used to match images taken by different cameras. Value can be:
- 0: Do not use time
- 1: Use time
<matchTimeMultiCamera>0</matchTimeMultiCamera> |
Matching Strategy |
Use Geometrically Verified Matching |
geometricallyVerifiedMatching |
Defines if geometrically verified matching should be used. Value can be:
- true: use geometrically verified matching
- false: do not use geometrically verified matching
<geometricallyVerifiedMatching>false</geometricallyVerifiedMatching> |
Calibration |
Option |
XML Tag |
Example |
Targeted Number of Keypoints |
keypointSelectionMethod |
Defines how to select the targeted number of keypoints to extract. Value can be:
- Automatic
- CustomNumber OfKeypoints
<keypointSelectionMethod>CustomNumberOfkeypoints</keypointSelectionMethod> |
numberOfKeypoints |
Used only if keypointSelectionMethod=CustomNumberOfkeypoints
Defines the number of targeted keypoints to extract. Value can be:
- an integer n such that 100 ≤ n ≤ 1'000'000
<numberOfKeypoints>10000</numberOfKeypoints> |
Calibration |
Calibration Method |
calibrationMethod |
Defines which calibration method to use. Value can be:
- Standard
- Alternative
- Accurate Geolocation and Orientation
<calibrationMethod>Standard</calibrationMethod> |
Optimizer |
optimizerType |
Defines the optimizer type to use. Value can be:
<optimizerType>Ceres</optimizerType> |
Internal Parameters Optimization |
internalParamOptimization |
Defines how to optimize the internal camera parameters. Value can be:
- None
- Leading
- All
- All Prior
<internalParamOptimization>All</internalParamOptimization> |
External Parameters Optimization |
externalParamOptimization |
Defines how to optimize the external camera parameters. Value can be:
<externalParamOptimization>All</externalParamOptimization> |
Rematch |
Rematch |
rematchStrategy |
Defines how to choose whether to rematch the images or not. Value can be:
- Auto: for Automatic
<rematchStrategy>Auto</rematchStrategy> |
Rematch |
rematch |
Used only if rematchStrategy = Custom
Defines if the images have to be rematched or not. Value can be:
- true: rematch images
- false: do not rematch images
<rematch>true</rematch> |
Pre-processing |
Sky Segmentation |
automaticSkyMasking |
Used only if the project consists of Parrot Bebop images.
Defines if masking the pixels that are covered by sky on the images is used. Value can be:
- true: masking is applied
- false: masking is not applied
<automaticSkyMasking>true</automaticSkyMasking> |
Export |
Camera Internals and Externals, AAT, BBA |
exportCameraParamsAATBBA |
Defines if the optimized camera internals and externals should be exported to files. Value can be:
- true: export to file
- false: do not export to file
<exportCameraParamsAATBBA>true</exportCameraParamsAATBBA> |
Undistorted Images |
exportUndistortedImages |
Defines if undistorted images should be generated. Value can be:
- true: generate undistorted images
- false: do not generate undistorted images
<exportUndistortedImages>false</exportUndistortedImages> |
2. Point Cloud and Mesh
Processing options for step 2. Point Cloud and Mesh. For more information: Menu Process > Processing Options... > 2. Point Cloud and Mesh > Point Cloud.
Run Step |
Option |
XML Tag |
Example |
Run step 2. Point Cloud and Mesh |
runStep |
Defines if step 2 should be run or not. Value can be:
- true: run step 2
- false: do not run step 2
Point Cloud |
Option |
XML Tag |
Example |
Point Cloud Densification |
Image Scale |
pclImageDownscaleFactor |
Defines the image scale used for densified point cloud. Value can be:
- 0: for 1 (Originial image size, Slow)
- 1: for 1/2 (Half image size, default)
- 2: for 1/4 (Quarter image size, Fast)
- 3: for 1/8 (Eighth image size, Tolerant)
<pclImageDownscaleFactor>1</pclImageDownscaleFactor> |
Multiscale |
pclImageMultiscale |
Defines if multi image scales should be used for point cloud densification. Value can be:
- true: do not use multiscale
- false: use multiscale
<pclImageMultiscale>true</pclImageMultiscale> |
Point Density |
pclDensity |
Defines which point density to obtain. Value can be:
<pclDensity>Optimal</pclDensity> |
Minimum Number of Matches |
pclMinNoMatches |
Defines the minimum number of matches. Value can be and integer n such that 2 ≤ n ≤ 6 |
<pclMinNoMatches>3</pclMinNoMatches> |
Export |
LAS |
pclExportLAS |
Defines if the densified point cloud should be exported in LAS format. Value can be:
- true: export densified point cloud in LAS format
- false: do not export densified point cloud in LAS format
<pclExportLAS>true</pclExportLAS> |
LAZ |
pclExportLAZ |
Defines if the densified point cloud should be exported in LAZ format. Value can be:
- true: export densified point cloud in LAZ format
- false: do not export densified point cloud in LAZ format
<pclExportLAZ>false</pclExportLAZ> |
PLY |
pclExportPLY |
Defines if the densified point cloud should be exported in PLY format. Value can be:
- true: export densified point cloud in PLY format
- false: do not export densified point cloud in PLY format
<pclExportPLY>false</pclExportPLY> |
XYZ |
pclExportXYZ |
Defines if the densified point cloud should be exported in XYZ format. Value can be:
- true: export densified point cloud in XYZ format
- false: do not export densified point cloud in XYZ format
<pclExportXYZ>false</pclExportXYZ> |
XYZ Delimiter |
pclExportXYZDelim |
Defines the delimiter of the XYZ file. Value can be:
- Space: for Space
- Tab: for Tab
- Comma: for Comma
- Semicolon: for Semicolon
<pclExportXYZDelim>Space</pclExportXYZDelim> |
Merge tiles |
pclExportMergeTiles |
If several tiles have been generated, defines if they should be merged into one single file. Value can be:
- true: merge point cloud tiles into a single file
- false: do not merge point cloud tiles into a single file
<pclExportMergeTiles>false</pclExportMergeTiles> |
3D Textured Mesh |
Option |
XML Tag |
Example |
Generation |
Generate 3D Texture Mesh |
meshGenerate3dTexturedMesh |
Defines if the 3D Textured Mesh should be generated or not. Value can be:
- true: generate 3D Textured Mesh
- false: do not generate 3D Textured Mesh
<meshGenerate3dTexturedMesh>true</meshGenerate3dTexturedMesh> |
Settings |
Mesh Resolution |
meshResolution |
Defines the resolution of the mesh. Value can be:
- High: for High Resolution
- Medium: for Medium Resolution (default)
- Low: for Low Resolution
<meshResolution>Medium</meshResolution> |
Maximum Octree Depth |
meshMaxOctreeDepth |
Defines the maximum depth of the octree used to create the mesh. Value can be:
- positive integer n such that 5 ≤ n ≤ 20
<meshMaxOctreeDepth>12</meshMaxOctreeDepth> |
Texture Size |
meshTextureSize |
Defines the mesh texture size. Value can be:
- 256: for 256x256
- 512: for 512x512
- 1024: for 1024x1024
- 2048: for 2048x2048
- 4096: for 4096x4096
- 8192: for 8192x8192
- 16384: for 16384x16384
- 32768: for 32768x32768
- 65536: for 65536x65536
- 131072: for 131072x131072
<meshTextureSize>8192</meshTextureSize> |
Decimation Criteria |
meshDecimationCriteria |
Defines how to decimate the mesh after it has been created. Value can be:
<meshDecimationCriteria>Quantitative</meshDecimationCriteria> |
Maximum Number of Triangles |
meshMaxTriangles |
Used when meshDecimationCriteria is Quantitative. Defines the maximum number of triangles for the mesh. Value can be:
- positive integer n such that 100 < n < 20'000'000
<meshMaxTriangles>1000000</meshMaxTriangles> |
Strategy |
meshDecimationStrategy |
Used when meshDecimationCriteria is Qualitative. Defines which qualitative strategy to use to decimate the mesh. Value can be:
<meshDecimationStrategy>Sensitive</meshDecimationStrategy> |
Use Color Balancing for Texture |
meshTextureColorBalancing |
Defines if color balancing should be used for the texture of the mesh. Value can be:
- true: use color balancing
- false: do not use color balancing
<meshTextureColorBalancing>false</meshTextureColorBalancing> |
Export |
PLY |
meshExportPLY |
Defines if the 3D textured mesh should be exported in PLY format. Value can be:
- true: export 3D textured mesh in PLY format
- false: do not export 3D textured mesh in PLY format
<meshExportPLY>false</meshExportPLY> |
FBX |
meshExportFBX |
Defines if the 3D textured mesh should be exported in FBX format. Value can be:
- true: export 3D textured mesh in FBX format
- false: do not export 3D textured mesh in FBX format
<meshExportFBX>false</meshExportFBX> |
AutoCAD DXF |
meshExportDXF |
Defines if the 3D textured mesh should be exported in AutoCAD DXF format. Value can be:
- true: export 3D textured mesh in AutoCAD DXF format
- false: do not export 3D textured mesh in AutoCAD DXF format
<meshExportDXF>false</meshExportDXF> |
OBJ |
meshExportOBJ |
Defines if the 3D textured mesh should be exported in OBJ format. Value can be:
- true: export 3D textured mesh in OBJ format
- false: do not export 3D textured mesh in OBJ format
<meshExportOBJ>true</meshExportOBJ> |
Tiled Texture |
meshExportTiledOBJ |
Defines if the 3D textured mesh should be exported in OBJ format with tiled texture. Value can be:
- true: export 3D textured mesh in OBJ format with tiled texture
- false: do not export 3D textured mesh in OBJ format with tiled texture
<meshExportTiledOBJ>false</meshExportTiledOBJ> |
3D PDF |
meshExportPDF3D |
Defines if the 3D textured mesh should be exported in 3D PDF format. Value can be:
- true: export 3D textured mesh in 3D PDF format
- false: do not export 3D textured mesh in 3D PDF format
<meshExportPDF3D>false</meshExportPDF3D> |
3D PDF Logo |
meshExportPDF3DLogoPath |
Defines if a logo should be displayed on the 3D PDF. Value can be:
- "": no logo is displayed
- "<path_to_logo>: logo given by the path is displayed
<meshExportPDF3DLogoPath></meshExportPDF3DLogoPath> |
Advanced |
Option |
XML Tag |
Example |
Matching Window Size |
pclWindowSize |
Defines the window size used for point cloud densification. Value can be:
<pclWindowSize>7</pclWindowSize> |
Image Groups |
Point Cloud |
pclImageGroups |
Defines which image groups to densify.
- <pclImageGroups/>: no group is densified
- <group name="group_name">: add a tag with the Image Group name for each image group to densify
<pclImageGroups> <group name="group1"/> </pclImageGroups> |
Mesh Geometry |
meshGeometryImageGroups |
- <meshGeometryImageGroups/>: no group is densified
- <group name="group_name">: add a tag with the Image Group name for each image group to use for the triangle mesh generation
<meshGeometryImageGroups> <group name="group1"/> </meshGeometryImageGroups> |
Mesh Texture |
meshTextureImageGroups |
- <meshTextureImageGroups/>: no group is densified
- <group name="group_name">: add a tag with the Image Group name for each image group to use for the texture generation
<meshTextureImageGroups> <group name="group1"/> </meshTextureImageGroups> |
Point Cloud Filters |
Use Processing Area |
pclUseProcessingArea |
Defines if the processing area (if defined) should be used or not. Value can be:
- true: use the processing area (if defined)
- false: do not use the processing area
<pclUseProcessingArea>true</pclUseProcessingArea> |
Use Annotations |
pclUseAnnotations |
Defines if the annotations (if existing) should be used or not. Value can be:
- true: use annotations (if existing)
- false: do not use annotations
<pclUseAnnotations>true</pclUseAnnotations> |
Limit Camera Depth Automatically |
pclLimitDepthAutomatically |
Defines if the camera depth should be automatically limited. Value can be:
- true: limit camera depth
- false: do not limit camera depth
<pclLimitDepthAutomatically>false</pclLimitDepthAutomatically> |
3D Textured Mesh Settings |
Sample Density Divider |
meshSampleDensityDivider |
Defines the value for the sample density divider. Value can be:
- a positive integers n such that 1 ≤ n ≤ 5
<meshSampleDensityDivider>1</meshSampleDensityDivider> |
LOD Generation |
OSGB |
lodExportOSGB |
Defines if the LOD should be exported in OSGB or not. Value can be:
- true: export LOD in OSGB
- false: do not export LOD in OSGB
<lodExportOSGB>true</lodExportOSGB> |
SLPK |
lodExportSLPK |
Defines if the LOD should be exported in SLPK or not. Value can be:
- true: export LOD in SLPK
- false: do not export LOD in SLPK
<lodExportSLPK>true</lodExportSLPK> |
Number of level of details |
lodLevelCount |
Defines the number of levels of detail to be generated. Value can be:
- a positive integers n such that 1 ≤ n ≤ 7
<lodLevelCount>4</lodLevelCount> |
Texture quality |
lodTextureQuality |
Defines the resolution of the texture for the LOD. Value can be:
- 0: for 512x512
- 1: for 1024x1024
- 2: for 4096x4096
<lodTextureQuality>512</lodTextureQuality> |
3. DSM, Orthomosaic and Index
Processing options for step 3. DSM, Orthomosaic and Index. For more information: Menu Process > Processing Options... > 3. DSM, Orthomosaic and Index > DSM and Orthomosaic.
Run Step |
Option |
XML Tag |
Example |
Run step 3. DSM, Orthomosaic and Index |
runStep |
Defines if step 3 should be run or not. Value can be:
- true: run step 3
- false: do not run step 3
DSM and Orthomosaic |
Option |
XML Tag |
Example |
Resolution |
Automatic |
orthoResolution |
Defines if the DSM and orthomosaic resolution is selected automatically as multiple of the GSD. Value can be:
- negative integer < 0: multiple of the GSD. For example "-2" will use 2xGSD
<orthoResolution value="-2"/> |
Custom [cm] |
orthoResolution |
Defines if the DSM and orthomosaic resolution is a user defined custom value. Value can be:
- positive decimal number > 0
<orthoResolution value="20"/> |
DSM Filter |
Use Noise Filtering |
dsmFilterUseNoiseFilter |
Defines if the noise filtering is used to generate the DSM. Value can be:
- true: use noise filtering
- false: do not use noise filtering
<dsmFilterUseNoiseFilter>true</dsmFilterUseNoiseFilter> |
Use Surface Smoothing |
dsmFilterUseSmoothing |
Defines if the surface smoothing is used to generate the DSM. Value can be:
- true: use surface smoothing
- false: do not use surface smoothing
<dsmFilterUseSmoothing>true</dsmFilterUseSmoothing> |
Type |
dsmFilterSmoothingType |
Defines the surface smoothing type. Value can be:
<dsmFilterSmoothingType>Sharp</dsmFilterSmoothingType> |
Raster DSM |
GeoTIFF |
dsmTIFF |
Defines if the DSM is generated in GeoTIFF format or not. Value can be:
- true: generate the DSM GeoTIFF
- false: do not generate the DSM GeoTIFF
<dsmTIFF>true</dsmTIFF> |
Method |
dsmMethod |
Defines which method is used to generate the DSM. Value can be:
- InverseDistanceWeighting
- Triangulation
<dsmMethod>InverseDistanceWeighting</dsmMethod> |
Merge Tiles |
dsmTIFFMergeTiles |
Defines if the DSM GeoTIFF tiles should be merged into one file or not. Value can be:
- true: merge tiles
- false: do not merge tiles
<dsmTIFFMergeTiles>true</dsmTIFFMergeTiles> |
Orthomosaic |
GeoTIFF |
mosaicTIFF |
Defines if the orthomosaic is generated in GeoTIFF format or not. Value can be:
- true: generate orthomosaic GeoTIFF
- false: do not generate orthomosaic GeoTIFF
<mosaicTIFF>true</mosaicTIFF> |
Merge Tiles |
mosaicTIFFMergeTiles |
Defines if the orthomosaic GeoTIFF tiles should be merged into one file or not. Value can be:
- true: merge tiles
<mosaicTIFFMergeTiles>true</mosaicTIFFMergeTiles> |
GeoTIFF without Transparency |
mosaicTIFFNoTransparency |
Defines if the orthomosaic without transparent backgroud should be generated or not. Value can be:
- true: generated orthomosaic without transparency
- false: do not generate orthomosaic without transparency
<mosaicTIFFNoTransparency>false</mosaicTIFFNoTransparency> |
Google Maps Tiles and KML |
mosaicKML |
Defines if the orthomosaic is generated in Google Maps Tiles and KML format or not. Value can be:
- true: generate orthomosaic in Google Maps Tiles and KML format
- false: do not generate orthomosaic in Google Maps Tiles and KML format
<mosaicKML>false</mosaicKML> |
Additional Outputs |
Option |
XML Tag |
Example |
Grid DSM |
XYZ |
gridDsmXYZ |
Defines if the Grid DSM should be generated in XYZ format or not. Value can be:
- true: generate Grid DSM in XYZ format
- false: do not generate Grid DSM in XYZ format
<gridDsmXYZ>false</gridDsmXYZ> |
XYZ Delimiter |
gridDsmXYZDelim |
- Space: for Space
- Tab: for Tab
- Comma: for Comma
<gridDsmXYZDelim>Space</gridDsmXYZDelim> |
LAS |
gridDsmLAS |
Defines if the Grid DSM should be generated in LAS format or not. Value can be:
- true: generate Grid DSM in LAS format
- false: do not generate Grid DSM in LAS format
<gridDsmLAS>false</gridDsmLAS> |
LAZ |
gridDsmLAZ |
Defines if the Grid DSM should be generated in LAZ format or not. Value can be:
- true: generate Grid DSM in LAZ format
- false: do not generate Grid DSM in LAZ format
<gridDsmLAZ>false</gridDsmLAZ> |
Grid Spacing [cm] |
gridDsmGridSpacing |
Defines the Grid Spacing for the Grid DSM. Value can be:
- a positive integer n such that 1 r≤ n ≤ 1000
<gridDsmGridSpacing>100</gridDsmGridSpacing> |
Raster DTM |
GeoTIFF |
dtmTIFF |
Defines if the raster DTM should be generated in GeoTIFF format or not. Value can be:
- true: generate the raster DTM in GeoTIFF format
- false: do not generate the raster DTM in GeoTIFF format
<dtmTIFF>true</dtmTIFF> |
Merge DTM tiles |
dtmTIFFMergeTiles |
Defines if the DTM GeoTIFF tiles should be merged into one file or not. Value can be:
- true: merge tiles
- false: not merge tiles
<dtmTIFFMergeTiles>true</dtmTIFFMergeTiles> |
Raster DTM Resolution |
Automatic |
dtmResolution |
Defines if the DTM resolution is selected automatically as multiple of the GSD. Value can be:
- negative integer < 5: multiple of the GSD. For example "-5" will use 5xGSD
<dtmResolution>-5</dtmResolution> |
Custom [cm] |
dtmResolution |
Defines if the DTM resolution is a user defined custom value. Value can be:
- positive decimal number > 5 and <10000
<dtmResolution>25</dtmResolution> |
Contour Lines |
SHP |
contourSHP |
Defines if the contour lines should be generated in SHP format. Value can be:
- true: generate contours in SHP format
- false: do not generate contours in SHP format
<contourSHP>false</contourSHP> |
PDF |
contourPDF |
Defines if the contour lines should be generated in PDF format. Value can be:
- true: generate contours in PDF format
- false: do not generate contours in PDF format
<contourPDF>false</contourPDF> |
AutoCAD DXF |
contourDXF |
Defines if the contour lines should be generated in AutoCAD DXF format. Value can be:
- true: generate contours in AutoCAD DXF format
- false: do not generate contours in AutoCAD DXF format
<contourDXF>false</contourDXF> |
Contour Base [m]
Contour Base [ft] |
contourBase |
Defines the value for the contour base. Value can be:
- a positive decimal number n such that 0 ≤ n ≤ 10'000
<contourBase>0</contourBase> |
Elevation Interval[m]
Elevation Interval[ft] |
contourElevationInterval |
Defines the value for the contour elevation. Value can be:
- a positive decimal number n such that 0.001 ≤ n ≤ 10'000
<contourElevationInterval>10</contourElevationInterval> |
Resolution [cm] |
contourResolution |
Defines the resolution of the contour lines. Value can be:
<contourResolution>100</contourResolution> |
Minimum Line Size [vertices] |
contourMinLineSize |
Defines the minimum number of vertices per line. Value can be:
- a positive integer n such that 4 ≤ n ≤ 1000
<contourMinLineSize>20</contourMinLineSize> |
Index Calculator |
Option |
XML Tag |
Example |
Resolution |
Automatic |
indexResolution |
Defines if the index resolution is selected automatically as multiple of the GSD. Value can be:
<indexResolution>-1</indexResolution> |
Custom [cm] |
indexResolution |
Defines if the index resolution is a user defined custom value. Value can be:
<indexResolution>0</indexResolution> |
Downsampling Method |
indexDownsamplingMethod |
Defines which downsampling method to use to generate the reflectance map at the given resolution from the 1 GSD reflectance map. Value can be:
- Gauss: for Gauss
- Median: for Median
- 75%Quantile: for 75%Quantile
- Average: for Average
- Min: for Min
- Max: for Max
<indexDownsamplingMethod>Gauss</indexDownsamplingMethod> |
Reflectance Map |
GeoTIFF |
indexReflectance |
Defines if the reflectance map should be generated in GeoTIFF format or not. Value can be:
- true: generate the reflectance map in GeoTIFF format.
- false: do not generate the reflectance map in GeoTIFF format.
<indexReflectance>false</indexReflectance> |
Merge Tiles |
indexReflectanceMergeTiles |
Defines if the reflectance map GeoTIFF tiles should be merged into one file or not. Value can be:
- true: merge tiles
<indexReflectanceMergeTiles>false</indexReflectanceMergeTiles> |
Indices |
Indices |
indices |
Defines the list of indices to generate. Each index is defined as follows: <index name="index_name" enabled="generate_index"> where:
- index_name: name of the index, either a pre-defined or user-defined index
- generate_index: can be:
- true: generate index
- false: do not generate index
<indices> <index name="red" enabled="true"/> <index name="green" enabled="true"/> <index name="blue" enabled="false"/> <index name="grayscale" enabled="false"/> </indices> |
Export |
Index Values as Point Shapefiles (SHP) |
indexExportPointSHP |
Defines if the values of the selected indices should be generated as point shapefile. Value can be:
- true: generate point shapefile
- false: do not generate point shapefile
<indexExportPointSHP>false</indexExportPointSHP> |
Index Values as Point Shapefiles (SHP) Grid Size [cm/grid] |
indexExportPointSHPGridSize |
Defines the grid size for the point shapefile. Value can be:
- a positive decimal number n such that 1 ≤ n ≤ 10'000
<indexExportPointSHPGridSize>200</indexExportPointSHPGridSize> |
Index Values and Rates as Polygon Shapefile (SHP) |
indexExportPolygonSHP |
Defines if the values of the selected indices should be generated as polygon shapefile. Value can be:
- true: generate polygon shapefile
- false: do not generate polygon shapefile
<indexExportPolygonSHP>false</indexExportPolygonSHP> |
Index Values and Rates as Polygon Shapefile (SHP) Grid Size [cm/grid] |
indexExportPolygonSHPGridSize |
Defines the grid size for the polygon shapefile. Value can be:
<indexExportPolygonSHPGridSize>400</indexExportPolygonSHPGridSize> |
How to create my own processing template?
Hi Tentao,
Please have a look at our article on how to create a User Processing Options Template.
I think our description which you will find there will dispel your doubts.
Best!
