In order to export marks:
- In Pix4Dmapper, click Project > GCP / MTP Manager...
- In section GCP/MTP Table, click Export Marks... The pop-up Export Image Marks opens.
- Navigate to the path where the marks file will be saved.
- On File name, type the desired file name.
- (optional) On Save as Type by default Pix4D marks files (*.txt, *.csv) is selected; to change to another output format: click Pix4D marks files (*.txt, *.csv) and select the desired format.
- Click Save.
- (optional) If a Pix4D marks files (*.txt, *.csv) was selected, the pop-up Pix4D Marks File Options opens. Select the Optional Data to be exported and the Data Separator and click OK. For more information: Menu Project > GCP / MTP Manager... > GCP / MTP Table > Import / Export Marks....
