Example Datasets Available for Download: DJI Demo
DJI Demo
The goal of this project is to get a 3D model of buildings using a DJI Phantom 2 Vision+ and acquiring the images with Pix4Dmapper Capture App.
3D Textured Mesh 3D Textured Mesh 3D Textured Mesh
General project information
Project
Location Switzerland
Average Ground Sampling Distance (GSD) 3.64 cm / 1.43 in
Area covered 0.0145 km2 / 1.4501 ha / 0.0056 sq. mi. / 3.5852 acres
Output coordinate system WGS84 / UTM zone 32N
Vertical Coordinate System: MSL egm96
Image acquisition
UAV DJI Phantom 2 Vision+
Image acquisition software Pix4Dmapper Capture App
Image acquisition plan Grid Mission, 90m x 90m, altitude = 50m
Camera Phantom Vision FC200
Images
Number of images 61
Image size 2304x1728 (half resolution of the original images)
Image geolocation coordinate system WGS84
Download* and project files
The dataset can be downloaded here.
The project can be found processed on Pix4D Cloud here
  • imagesRGB images in JPG format. The image's resolution is half the original image resolution.
  • dji_demo.p4dproject file that can be opened in Pix4Dmapper.
*The usage of this dataset is meant to be for personal and professional training. If you would like to use it for commercial or promotional objectives, please be sure to mention "Courtesy of Pix4D / pix4d.com" linking all this text to pix4d.com.
Instructions
This section describes how to process the dataset using the included .p4d project file in order to generate a 3D mesh of buildings.
1. Open the project dji_demo.p4d
2. On the menu bar, click View > Processing. The Processing window opens at the bottom of the main window.
3. On the Processing window, click Start to start the processing.
Note: As the goal of this project is to get a 3D Model, a DSM and an orthomosaic, the template used for the processing has been set to 3D Maps. This can be seen in Process > Processing Options.... .
0 out of 0 found this helpful
Powered by Zendesk
