How to import a volume into Volumes - PIX4Dmapper
This article provides step-by-step instructions on importing a volume into the Volumes window.
Important:
  • In order to import a volume into Volumes, the dense point cloud and the digital surface model (DSM) should be computed.
  • A volume should contain 3D surfaces to be imported as a shapefile (.shp).
  • The shapefile coordinate system and the PIX4Dmapper project's output coordinate system should agree.
To import a volume into the Volumes:
1. On the Menu bar, click View > Volumes.
2. On the sidebar, in the Objects section, click  Import base surface(s).
Import volume base surface in PIX4Dmapper
3. The Import Volume window appears. Navigate to the desired shapefile, in this example, the desired shapefile is named Volume_ToImport_surface.shp.
4. Select the file and click Open.
The volume is now imported and selected to be displayed in Volumes.
By default, the volume is called Volume 1, but it can be renamed by double-clicking on the name and typing the new name.
7 out of 9 found this helpful
2 comments
  • Sam Atinga
    When i import a surface created outside (or even edited in another bit of software), is there anyway to ensure it is draped to the DSM to give me the correct volume?
  • Yuka (Pix4D)
    Hello Sam,
    If I understood your question correctly, you can import a shapefile that has the same coordinate system and check the coordinates of points by looking at the right bottom of the Pix4Dmapper. You can also check visually by looking at the rayCloud.
    Kind regards,
