How to Split a Project into Subprojects
Important: Only aerial projects with geolocated images can be split.
In order to split a project into sub-projects:
1. Click Project > Split into Subprojects...
2. (optional) On the Split the Project into Subprojects pop-up, change the Maximum Number of Images to the desired value and/or the Suffix of the Subproject's Name. For more information about the setting options: 202557559.
3. Click OK.
Note: For each new sub-project, a new .p4d file is generated and stored in the same directory as the initial project.
Important: All the Manual Tie Points, GCPs, check points and Objects created in the original project, will be copied into all the generated sub-projects.
0 out of 0 found this helpful
