Troubleshooting
Warning w0026: "Loading results failed: Incorrect coordinate system." - PIX4dmapper
Warning
"Loading results failed: Incorrect coordinate system".
Description
When opening a project previously processed, the following warning message is displayed:
Cause
One possible cause is that the user had an initial coordinate system for the project and then added GCPs with a different coordinate system without Reoptimizing.
Solution
The results cannot be loaded. The project needs to be processed again. When adding GCPs to a project, the user should always Reoptimize before running other steps of processing and / or closing the project.
