Index > Interface > Menu Process | Previous | Next |
This feature allows to:
- View/edit the processing options:
- Selecting which outputs are generated and in which format.
- Assigning hardware resources to the processing.
- Select a processing options template.
- Create a new processing options template.
- Manage the processing options template.
It contains three sections:
- Processing steps and resources: Allows the user to select a step or the resources in order to visualize/edit options.
- Tabs associated with the selected step or resources: Allows the user to visualize/edit the processing options, outputs and/or resources for the selected step/resource.
- Processing options template: Allows the user to select a template, save a custom template and manage templates.
And four actions:
- OK: Confirms the changes.
- Cancel: Does not save the changes.
- Advanced options: Displays/hides the advanced options tabs, available for 1. Initial Processing and 2. Point Cloud and Mesh.
