It is possible to export into file:
- Export Image Geolocation: For images, the coordinates and, optionally, the orientation and/or the accuracy of the coordinates.
- Export Ground Control Points: For GCPs and Check Points, the coordinates and, optionally for GCPs, the accuracy of the coordinates.
Displays the following options:
- Attributes: Defines which attributes are exported:
- Name, Coordinates, Orientation, Accuracy (default)
- Coordinates
- Name, Coordinates
- Coordinates Order: Defines the type of coordinates and in which order they are stored:
- For geographic WGS84 (longitude, latitude, altitude):
- Latitude, Longitude, Altitude(default)
- Longitude, Latitude, Altitude
- For image geolocation coordinates that are given in any coordinate system (X,Y,Z) apart from WGS84 geographic coordinates:
- X, Y, Z (default)
- Y, X, Z
Delimiter: It defines the delimiter character of the file, used to separate the values. The drop down list has the following options:
- Comma (default)
- Space
- Tab
- Semicolon
- File: Shows the path and name where the file will be stored.
And the buttons:
- Browse: Navigates to the path where the file will be stored.
- OK: Confirms and applies the changes.
- Cancel: Do not save the changes and exit.
For more information about the format of the exported file: Input files.
- Label, Coordinates (default)
- Coordinates
- Label, Coordinates, Accuracy
- For geographic WGS84 (longitude, latitude, altitude), GCPs/Check Points coordinates:
- Latitude, Longitude, Altitude (default)
- For GCPs/Check Points coordinates that are given in any coordinate system (X,Y,Z) apart from WGS84 geographic coordinates:
- X, Y, Z (default)
- Y, X, Z
- Comma (default)
- Space
- Tab
- Semicolon
And the buttons:
