(Android) Pix4Dcapture Release 1.0
Download the Android App here or via Google play (click below for direct access):
Get it on Google Play
VersionRelease dateRelease type
1.0.2 June 23, 2015 New release
1.0.1 May 30, 2015 New release
Version 1.0.2
Improvements
  • Speed is reduced by 10% to ensure that images are properly taken.
Bug fixes
  • Fixed a bug that prevented some drones from flying the 7th line.
Version 1.0.1
What is new
  • New interface for Grid Mission Map View
    A new interface for the Map View allows to position, rotate and resize the grid and get an immediate response for the mission directly on the map view.
  • Select flight altitude
    Select the flight altitude for the Grid Mission directly in the Map View.
  • Select overlap
    Select the overlap between the images for the Grid Mission in the App Settings.
Improvements
  • New interface for Free Flight Mission Map View
    A new interface allows to directly set the minimum horizontal and vertical distance between two images in the Map View.
  • Improved upload to Pix4D Cloud
    If upload is interrupted and resumed, the upload starts from the last image fully uploaded.
  • Disable automatic mission synchronization
    Disable the automatic mission synchronization in the App Settings. The missions can be synchronized at a later stage.
  • Video stream
    Improved video stream stability in the camera view during flight.
Bug fixes
  • Various bug fixes
0 out of 0 found this helpful
