Error e0046: "Processing failed. Generating grayscale normalized image: cannot read from <filename> rect [...]."
Error
Description
When processing step 1. Initial Processing, the processing stops and shows the message: e0046: "Processing failed. Generating grayscale normalized image: cannot read from <filename> rect [...]."
Where <filename> is the name of an image of the project.
Cause
Possible causes:
  • The image file could be opened but could not be read because the file is corrupted.
  • rect is the coordinates of the rectangle defining the image. If the image needs to be tiled, it contains the coordinates of the image tile. If the coordinates are outside the images size, the file cannot be read.
Solution
  • Verifiy that the image file is not corrupted. For more information: 203032329.
  • Verifiy that the rectangle is not outside the image size. For more information: 203032339.
0 out of 0 found this helpful
