Error e0046: "Processing failed. Generating grayscale normalized image: cannot open file for writing."
Error
Description
When processing step 1. Initial Processing, the processing stops and shows the message: e0046: "Processing failed. Generating grayscale normalized image: cannot open <filename> for writing."
Where <filename> is a grayscale image that is generated during step 1. Initial Processing.
Cause
The file could not be opened for writing because the target directory does not exist or does not have write permission.
Solution
Verify that the target directory exists and has write permission. For more information:203756005.
0 out of 0 found this helpful
Powered by Zendesk
