Error e0046: "Processing failed. Invalid output coordinate system."
Error
Description
When processing step 1. Initial Processing, the processing stops and shows the message: e0046: "Processing failed. Invalid output coordinate system."
Cause
There is no transformation between image and output coordinate system or GCP and output coordinate system.
Solution
  • Verify that the image geolocation and coordinate system is correct. For more information: 203755985.
  • Verify that the GCP geolocation and coordinate system is correct. For more information: 203032299.
0 out of 0 found this helpful
Powered by Zendesk
