How to split a project into subprojects
A dataset can be divided into subprojects either automatically using the Split into Subprojects option or manually.
Note: Only if the dataset has image geolocation it can be divided into subprojects using the Split into Subprojects option. If the dataset does not have image geolocation, it can be divided into subprojects manually.
1. Dataset with image geolocation
2. Dataset without image geolocation
Important: Only aerial projects with geolocated images can be split.
In order to split a project into subprojects:
1. Click Project > Split into Subprojects...
2. (optional) On the Split the Project into Subprojects pop-up, change the Maximum Number of Images to the desired value and/or the Suffix of the Subproject's Name. For more information about the setting options: Menu Project.
3. Click OK.
Note: For each new sub-project, a new .p4d file is generated and stored in the same directory as the initial project.
Important: All the Manual Tie Points, GCPs, check points and Objects created in the original project, will be copied into all the generated sub-projects.
One-flight Aerial Project
Estimate the distance between the flight lines. It is recommended to divide the dataset in flight lines that have the smallest distance between them, so as to maximize the overlap between the subprojects.
Example:
The yellow area is the area covered by the left subproject. The blue area is the area covered by the right sidebar.
The green area is the common area between the two subprojects.
Tip: If there are more than 3 GCPs in the original project, it is recommended to split the project so that there are at least three GCPs in each subproject, if possible.
Several-flight Aerial Project
Fly the different flights so that there is common area covered by as many flights as possible. Each flight can be one subproject.
Important: When dealing with multiple flights, multiple image acquisition sessions or more generally when dealing with images that have the same name, save the images of each flight / image acquisition session in one folder.
Terrestrial Project
Split the project into subprojects in such a way so that different subprojects share common images. This will ensure that there is overlap between the subprojects, which will facilitate merging.
Tip: Error e9013: Could not save subprojects, for more information: Error e9013: Could not split projects
5 out of 12 found this helpful
6 comments
  • Pritpal Singh
    Ref. Demo Highway Project 8kms ( Image Attached )
    I am looking for splitting the model into 450m Section to understand how Visual Line of Site Range of 1/4NM.
    also I am looking for a DEMO model split into sections to practice Merge option. Please advise.
  • Holden (Pix4D)
    Hi Pritpal, Splitting into a subproject is something that occurs before processing and is typical to reduce the processing overhead for larger projects. Once a project has finished processing Pix4D does not have a feature to split. You can likely accomplish this by importing the data into another application like QGIS for the raster products or CloudCompare for the point cloud.
  • Pritpal Singh
    Holden, understood. next, if I have a Road with one side UAV access and road is aprox. 30ft wide. also if can not flight double track. I am unable to find single track capture mission. please advice.
  • Holden (Pix4D)
    Single flight corridor missions are not advisable as they are susceptible to the accumulation of geometric error. It is recommended that you have at least two adjacent flight lines. Also, GCPs are important for these sorts of missions if absolute and relative accuracy is a priority. For that reason, single flight lines are not supported in Pix4D Capture.
  • Pritpal Singh
    Holden,
    if the limitation is the requirement then how to handle. Please find the snippet of the road project with one side access and needs to be mapped. please advise a resolution under limitations. the other side is no fly zone.
    Thanks
  • Holden (Pix4D)
    Hi Pritpal. As this is not relevant to the topic of this page I would suggest you create a new community Post HERE or open a support request by clicking Contact support on the page HERE
