The status of Pix4Dcapture regarding the different drones, cameras, and controllers is described in the table below. When the app has not been tested, it means that the app could work but Pix4D makes no guarantee.
If a non-DJI camera is mounted on DJI drones, Pix4Dcapture will not be able to trigger the camera. Making it work will rely on the fact that a time-lapse can be set in this custom camera. A specific functionality has been developed on iOS to keep the right overlap up to the camera specifications. More information here.
Manufacturer | Drone / Camera / Controllers | Android | iOS |
DJI drones | Inspire 1 (X3, X5, XT) | Compatible (2.0.6 and later) | Compatible (1.0.0 and later) |
Inspire 2 (X4S, X5S) | Compatible (3.8.1 and later) | Compatible (1.7.1 and later) | |
Mavic Air | Compatible (4.3.0 and later) | Compatible (3.2.0 and later) | |
Mavic Air 2 | Not compatible | Not compatible | |
Mavic Mini | Not compatible | Not compatible | |
Mavic Pro | Compatible (3.5.0 and later) | Compatible (1.6.0 and later) | |
Mavic 2 Pro | Compatible (4.5.0 and later) | Compatible (4.1.0 and later) | |
Mavic 2 Zoom | Not compatible | Not compatible | |
Mavic 2 Enterprise (Zoom) | Not compatible | Not compatible | |
Mavic 2 Enterprise (Dual) | Not compatible | Compatible only with RGB (4.7.0 and later) | |
Mavic 3 | Not compatible | Not compatible | |
Matrice 100 (X3, X5, XT) | Compatible (3.1.1 and later) | Compatible (1.4.0 and later) | |
Matrice 200 | Compatible (4.1.1 and later) | Compatible (2.9.2 and later) | |
Matrice 200 V2 series | Not compatible | Compatible - Not tested (4.10.0 and later) | |
Matrice 210 | Compatible (4.1.1 and later) | Compatible (2.9.2 and later) | |
Matice 210 V2 | Not tested | Not tested | |
Matrice 210 RTK | Compatible (4.1.1 and later) | Compatible (2.9.2 and later) | |
Matrice 300 RTK | Not compatible | Not compatible | |
Matrice 600 (X3, X5, XT) | Not tested | Compatible (2.0.0 and later) | |
Phantom 1 | Not compatible | Not compatible | |
Phantom 2 | Not compatible | Not compatible | |
Phantom 2 Vision | Not compatible | Not compatible | |
Phantom 2 Vision+ | Not compatible | Not compatible | |
Phantom 3 Advanced | Compatible (2.0.6 and later) | Compatible (1.0.0 and later) | |
Phantom 3 Professional | Compatible (2.0.6 and later) | Compatible (1.0.0 and later) | |
Phantom 3 Standard | Compatible (3.1.0 and later) | Compatible (1.0.0 and later) | |
Phantom 3 4K | Not tested | Not tested | |
Phantom 4 | Compatible (3.1.0 and later) | Compatible (1.2.0 and later) | |
Phantom 4 Advanced | Not tested | Not tested | |
Phantom 4 Pro V1 | Compatible (3.6.0 and later) | Compatible (1.6.1 and later) | |
Phantom 4 Pro+ V1 | Not tested | Not compatible | |
Phantom 4 Pro V2.0 | Compatible (4.3.2 and later) | Compatible (3.4.0 and later) | |
Phantom 4 Pro+ V2.0 | Not compatible | Not compatible | |
P4 Multispectral | Not compatible | Not compatible | |
Spark (Free flight mission only) | Compatible (3.8.5 and later) | Compatible (2.3.0 and later) | |
DJI cameras | Zenmuse XT | Compatible (3.6.0 and later) | Compatible (2.0.0 and later) |
Zenmuse XT2 | Not compatible | Compatible - Not tested (4.10.0 and later) | |
Zenmuse X3 | Compatible (2.0.6 and later) | Compatible (1.0.0 and later) | |
Zenmuse X4S | Compatible (3.8.1 and later) | Compatible (1.7.1 and later) | |
Zenmuse X5 | Compatible (2.1.1 and later) | Compatible (1.2.0 and later) | |
Zenmuse X5R | Not tested | Not tested | |
Zenmuse X5S | Not tested, compatible (3.8.1 and later) | Compatible (1.7.1 and later) | |
Zenmuse X7 | Not compatible | Not compatible | |
Zenmuse Z3 | Not compatible | Compatible - Not tested (4.10.0 and later) | |
Zenmuse Z30 | Not compatible | Compatible - Not tested (4.10.0 and later) | |
DJI controllers | Smart controller | Not compatible | Not compatible |
Parrot drones | Anafi | Compatible (4.4.0 and later) | Compatible (4.0.0 and later) |
Anafi Thermal (RGB+ Thermal images) | Compatible (4.8.0 and later) | Compatible (4.8.0 and later) | |
Anafi USA (RGB only) | Compatible (4.10.0 and later) | Compatible (4.11.0 and later) | |
Bebop 1 | Not compatible | Not compatible | |
Bebop 2 using Wifi | Not compatible | Not compatible | |
Bebop 2 with Skycontroller 2 | Compatible (2.1.1 and later) | Compatible (1.1.0 and later) | |
Bluegrass | Compatible (4.1.0 and later) | Compatible (2.7.0 and later) | |
Disco | Not compatible | Not compatible | |
Disco-Pro AG | Not compatible | Compatible (2.0.0 and later) | |
Parrot controllers | Skycontroller | Not compatible | Not compatible |
Skycontroller 2 | Compatible (3.8.0 and later) | Compatible (1.6.0 and later) | |
Skycontroller 3 | Compatible (4.4.0 and later) | Compatible (4.0.0 and later) | |
Yuneec drones | H520 | Compatible (4.2.0 and later) | Not compatible |
Yuneec cameras | E90 | Compatible (4.2.0 and later) | Not compatible |
Yuneec controllers | ST16, ST16S | Compatible (4.2.0 and later) | Not compatible |
3DR | Solo (GoPro Hero 4 Black or Silver) | Not compatible | Not compatible (no iOS SDK) |
Recommendations to fly a drone that was not tested
The drone to be selected before starting a mission should be one of those having the same connection mode (Wi-Fi or USB cable).
Hello Ivan,
The Mavic 2 Enterprise is only supported on the iOS version of Pix4Dcapture. However, the Pix4Dcapture app is only compatible with the RGB camera. If you have any issues, I would suggest you go through all the basic checks and troubleshooting steps as it will solve most of the issues that can be encountered if properly followed.
Regards,
Gostaria de saber se tem compatibilidade com o drone fimi x8 se dá xiaomi
Hi Gabriel, It is not compatible with Xiaomi FIMI X8.
Hello I want to know if the mvick air 2 will be support at some point?
thanks
Hi Juan,
Supporting the DJI Mavic Air 2 is not in our roadmap for this year. If we support this drone, we will notify our users in our social media.
Kind regards,
Hola
Tengo un dron Phantom 3 estandar y actualmente no me deja realizar el plan de vuelo con la aplicación Pix4Dcapture
Hello,
The behavior you are describing can’t be replicated on our side and has not been reported to us so far. I would suggest you go through all the [basic checks and troubleshooting steps] as it will solve most of the issues that can be encountered if properly followed.
Regards,
Hello,
Will skydio 2 be supported by pix4d?
Thanks.
Hi,
The Skydio 2 is not supported by Pix4Dcapture at the moment and it is currently not in our pipeline to support it. However, your interest has been shared with the team and any updates will be published on this page.
Hi
In future there are any possibilty tha Pix4d can be avaible on Dji Matrice 300 RTK ?
If yes, When ?
Thanks and bestregards
Hello Gianni,
The DJI Matrice 300 RTK is not supported by pix4Dcapture at the moment and it is currently not in our pipeline to support it by the first quarter of 2021. If things change, we will publish it at our page on Supported drones, cameras and controllers.
I would also recommend you to go through our support article on Which image acquisition app can I use with Pix4D’s software?.
Hi,
Since the SDK for the DJI Mavic Mini has been available since the end of July 2020, I was wondering whether or not Pix4d were working to make it compatible with the application. I know many people, including myself, would love to see Pix4d be compatible with the mini drone.
Buenos días..
Cuando podremos soportar el DJI Mavic Air 2 con la app de Pix4d capture,
Cuando harán la actualización?
There are no plans for the Pix4Dcapture app to support the DJI Mavic Air 2 in 2020.
You can find more information on our forum
Since the upgrading of Anafi Parrot to firmware 1.7, Pix4D mapper is not working anymore on Android
Hello,
The Parrot Anafi won't work with the recent firmware update of 1.7.3. We will release a new version for Pix4Dcapture android within a few weeks and it should work with that version.
For now, the only option is not updating the firmware to 1.7 or using the iOS version of the Pix4Dcapture app.
Regards,
Hi,
Anyone to please update me on this:
Has anyone tried flying missions using Pix4dCapture on Android with the Matrice 200 v2 (just want to know if it is now compatible)? It is annoying that one can't import kml files into the iOs version of Pix4dCapture especially if you need the mission to accurately overlay the area of interest.
Are there any plans to make this possible for users, it has been requested by several pix4d community members already.
Buonasera io ho un mavic air 2 e al momento px4d non è supportato. Quando è possibile utilizzare la app? Grazie e buona serata
Hello,
At the moment and it is currently not in our pipeline to support it. If things change, we will publish it on our page on Supported drones, cameras, and controllers.
I'm disappointed to see the DJI Mavic 2 Zoom is not supported. Can you explain the reason for this? Thank you, Michael
Hello good news from DJI regarding the SDK allowing 3rd party support for the Mavic Air 2:
Dear Developer, We are excited to announce the release of the DJI Mobile SDK 4.14 Trial1 and DJI UX SDK 4.14 Trial1. You can find them on our developer site at DJI MSDK Download 2, DJI UXSDK Download.
This version of Mobile SDK introduces support for DJI Mavic Air 2 and adds some new features for Matrice 300 RTK, including the selection of lens to for taking photos or recording videos, custom file name and folder name for manual flight and waypoint flight, and support radar accessories for obstacle avoidance. Also, we added some new features for Phantom 4 RTK, including fetch XMP file from camera and support maintain positioning accuracy mode. In addition, we have fixed some serious bugs. Please refer to the release notes for the full list of changes.
This version of UX SDK introduces support for Mavic Air 2 and fixes for various bugs. We are transitioning towards an upcoming major version of UX SDK, version 5.0, which is open source, modular and customizable. Shortly after this 4.14 release, you will find the new iOS UXSDK version 5 beta 4 1 and Android UX SDK version 5 beta 5 1 on Github. We look forward to all of your feedback and pull requests.
As always, the DJI Dev Team is committed to improving your developer experience. Please report any bugs or questions you have to dev@dji.com. We recommend frequently checking the DJI SDK Download Page to ensure that you are always working with the latest version of the DJI SDK.
If you don’t want to subscribe news about our SDK anymore, you can go to our developer website to unsubscribe it. You can go to the link below to unsubscribe.
link: https://developer.dji.com/user/account 1
If you would like to contribute or ask questions to the DJI Developer Community please check out DJI Developer Forum here: EN CN.
Best, The DJI Developer Technologies Team
Good morning, recently DJI has released compatible SDK for DJI Mavic Air 2, the question is easy.
Will you make Pix4D compatible with Mavic Air 2? When?
Good morning, recently DJI has released a compatible SDK for DJI Mavic Air 2 v.2020.12.10, the question is easy.
Hello, thanks for posting the news!
Unfortunately, there are no plans to support the Mavic Air 2 in Pix4Dcapture.
If anything changes, we will communicate on the official post for Mavic Air 2:
DJI Mavic air 2 and Pix4Dcapture
Does anyone know if there is plans for the Mavic Air 2 to be supported?
Hello! Pix4Dcapture, our flying app does not support the Mavic Air 2.
Please keep in mind that our processing software such as Pix4Dmapper can process images taken from virtually any flying app as long as they are of good quality and overlap. For more information: Which image acquisition app can I use with Pix4D's software?.
That being said, you can get a trial of our processing software and start using them with your Mavic Air 2 images at any moment.
I will consider Pix4Dmapper when I can use Pix4Dcapture. The SDK has been available so your software should be made to support the Mavic Air 2. Let us know when it is available.
I need your support for Mavic air2. When can I apply?
I would like to continue Pix4d Mapper, but, my drone is 'DJI matrice 300 RTK'. Do you a plan for the drone to use ?
Hello Jaeho,
Currently, there is no plan to add the DJI matrice 300 RTK in Pix4Dcapture.
