The status of Pix4Dcapture regarding the different drones, cameras, and controllers is described in the table below. When the app has not been tested, it means that the app could work but Pix4D makes no guarantee.
If a non-DJI camera is mounted on DJI drones, Pix4Dcapture will not be able to trigger the camera. Making it work will rely on the fact that a time-lapse can be set in this custom camera. A specific functionality has been developed on iOS to keep the right overlap up to the camera specifications. More information here.
Manufacturer | Drone / Camera / Controllers | Android | iOS |
DJI drones | Inspire 1 (X3, X5, XT) | Compatible (2.0.6 and later) | Compatible (1.0.0 and later) |
Inspire 2 (X4S, X5S) | Compatible (3.8.1 and later) | Compatible (1.7.1 and later) | |
Mavic Air | Compatible (4.3.0 and later) | Compatible (3.2.0 and later) | |
Mavic Air 2 | Not compatible | Not compatible | |
Mavic Mini | Not compatible | Not compatible | |
Mavic Pro | Compatible (3.5.0 and later) | Compatible (1.6.0 and later) | |
Mavic 2 Pro | Compatible (4.5.0 and later) | Compatible (4.1.0 and later) | |
Mavic 2 Zoom | Not compatible | Not compatible | |
Mavic 2 Enterprise (Zoom) | Not compatible | Not compatible | |
Mavic 2 Enterprise (Dual) | Not compatible | Compatible only with RGB (4.7.0 and later) | |
Mavic 3 | Not compatible | Not compatible | |
Matrice 100 (X3, X5, XT) | Compatible (3.1.1 and later) | Compatible (1.4.0 and later) | |
Matrice 200 | Compatible (4.1.1 and later) | Compatible (2.9.2 and later) | |
Matrice 200 V2 series | Not compatible | Compatible - Not tested (4.10.0 and later) | |
Matrice 210 | Compatible (4.1.1 and later) | Compatible (2.9.2 and later) | |
Matice 210 V2 | Not tested | Not tested | |
Matrice 210 RTK | Compatible (4.1.1 and later) | Compatible (2.9.2 and later) | |
Matrice 300 RTK | Not compatible | Not compatible | |
Matrice 600 (X3, X5, XT) | Not tested | Compatible (2.0.0 and later) | |
Phantom 1 | Not compatible | Not compatible | |
Phantom 2 | Not compatible | Not compatible | |
Phantom 2 Vision | Not compatible | Not compatible | |
Phantom 2 Vision+ | Not compatible | Not compatible | |
Phantom 3 Advanced | Compatible (2.0.6 and later) | Compatible (1.0.0 and later) | |
Phantom 3 Professional | Compatible (2.0.6 and later) | Compatible (1.0.0 and later) | |
Phantom 3 Standard | Compatible (3.1.0 and later) | Compatible (1.0.0 and later) | |
Phantom 3 4K | Not tested | Not tested | |
Phantom 4 | Compatible (3.1.0 and later) | Compatible (1.2.0 and later) | |
Phantom 4 Advanced | Not tested | Not tested | |
Phantom 4 Pro V1 | Compatible (3.6.0 and later) | Compatible (1.6.1 and later) | |
Phantom 4 Pro+ V1 | Not tested | Not compatible | |
Phantom 4 Pro V2.0 | Compatible (4.3.2 and later) | Compatible (3.4.0 and later) | |
Phantom 4 Pro+ V2.0 | Not compatible | Not compatible | |
P4 Multispectral | Not compatible | Not compatible | |
Spark (Free flight mission only) | Compatible (3.8.5 and later) | Compatible (2.3.0 and later) | |
DJI cameras | Zenmuse XT | Compatible (3.6.0 and later) | Compatible (2.0.0 and later) |
Zenmuse XT2 | Not compatible | Compatible - Not tested (4.10.0 and later) | |
Zenmuse X3 | Compatible (2.0.6 and later) | Compatible (1.0.0 and later) | |
Zenmuse X4S | Compatible (3.8.1 and later) | Compatible (1.7.1 and later) | |
Zenmuse X5 | Compatible (2.1.1 and later) | Compatible (1.2.0 and later) | |
Zenmuse X5R | Not tested | Not tested | |
Zenmuse X5S | Not tested, compatible (3.8.1 and later) | Compatible (1.7.1 and later) | |
Zenmuse X7 | Not compatible | Not compatible | |
Zenmuse Z3 | Not compatible | Compatible - Not tested (4.10.0 and later) | |
Zenmuse Z30 | Not compatible | Compatible - Not tested (4.10.0 and later) | |
DJI controllers | Smart controller | Not compatible | Not compatible |
Parrot drones | Anafi | Compatible (4.4.0 and later) | Compatible (4.0.0 and later) |
Anafi Thermal (RGB+ Thermal images) | Compatible (4.8.0 and later) | Compatible (4.8.0 and later) | |
Anafi USA (RGB only) | Compatible (4.10.0 and later) | Compatible (4.11.0 and later) | |
Bebop 1 | Not compatible | Not compatible | |
Bebop 2 using Wifi | Not compatible | Not compatible | |
Bebop 2 with Skycontroller 2 | Compatible (2.1.1 and later) | Compatible (1.1.0 and later) | |
Bluegrass | Compatible (4.1.0 and later) | Compatible (2.7.0 and later) | |
Disco | Not compatible | Not compatible | |
Disco-Pro AG | Not compatible | Compatible (2.0.0 and later) | |
Parrot controllers | Skycontroller | Not compatible | Not compatible |
Skycontroller 2 | Compatible (3.8.0 and later) | Compatible (1.6.0 and later) | |
Skycontroller 3 | Compatible (4.4.0 and later) | Compatible (4.0.0 and later) | |
Yuneec drones | H520 | Compatible (4.2.0 and later) | Not compatible |
Yuneec cameras | E90 | Compatible (4.2.0 and later) | Not compatible |
Yuneec controllers | ST16, ST16S | Compatible (4.2.0 and later) | Not compatible |
3DR | Solo (GoPro Hero 4 Black or Silver) | Not compatible | Not compatible (no iOS SDK) |
Recommendations to fly a drone that was not tested
The drone to be selected before starting a mission should be one of those having the same connection mode (Wi-Fi or USB cable).
Bonjour,
Nous avons déjà réalisé plusieurs vols avec PIX4D et hier lors de nos séances de vols les photos sont toutes floues alors que nous n'avons touché à aucun réglage donc je ne peux traiter aucune image.
Pour info nous avons un matrice 210 RTK avec zenmuse X5S.
Cordialement
Bonjour Bernard,
Nous avons répondu à votre requête via notre système de support.
Salutations,
Hello! I have a question about camera angle on my P3A drone. In Pix4Capture I don't know where I can change camera angle for example in circular missions. Camera set by 80 degrees, but I need a less value. In "eStarting manual describes what a value angle set by 45 degree and 30 degree. How can i do this?
This is the picture from your "Getting started.." - So I can't do this. Can I change camera angle or this is goinf on automatically?
Hello Dmitry,
The tilting angle of the camera can not be set for circular missions. It is implemented so that the camera will face the center of the mission, looking at the ground all the time.
For other missions, the tilting angle can be set in the settings.
You can have a look at the different parameters for Android or iOS.
Best,
Hi, selamat malam, saya pengguna mavic 2 pro ketika saya buka pix4d capture dan melakukan misi tampilan kamera nya tidak ada, hanya ada layar blank hitam saja. Kira kira apa ya masalah nya? Sebelumnya saya pake p4 pro tidak ada masalah seperti ini. Tolong solusi nya. Terima kasih
PS : pakai handphone android blackshark 2
@Mavic Reklamasi,
The live video feed for the Mavic 2 Pro has not been implemented on the Android version of Pix4Dcapture. It is then normal that you will see a black screen when looking at it.
Best,
When will be implemented on mavic 2 pro? Is iOS support for live video on pix4d capture?
Hi Mavic Reklamasi,
Currently, the video live feed is not working for the Mavic 2 Pro using the iOS version of Pix4Dcapture. It is a known issue that will be fixed in the next release.
For the Android version of Pix4Dcapture, I can not give you any timeline when/if it will be implemented.
Best,
Hi.
I have mavic 2 zoom, and the app works fine. why table contains information, that is mavic 2 is not supported?
Hi,
The Mavic 2 Zoom is not officially supported by Pix4Dcapture as we did not test it with our app. It might work with it but we make no guarantee. Also, as it is a zoom drone, the focal length might change during an acquisition and impact the image process and outputs afterward.
Will Pix4D support the mavic mini in the future?
Hi Keegan,
So far this drone has just been released so we need to evaluate if we will support it with Pix4Dcapture. In any case, DJI needs to provide an SDK that would enable third-party apps like Pix4Dcapture to be able to support the Mavic Mini, which is not the case for the moment.
Best
Hello, I would like to know if mavic mini will be supported by Pixel4D? I'm interested in using the drone for mappings.
Hi Ariel,
Don't hesitate to open a thread on our community to talk about this topic.
Best,
Has there been any additional insight as to when we could expect functionality with the Matrice V2 Series aircraft? Considering its versatility, I can not believe that it has not been added as a priority for compatibility. Is Pix4D just not going to work with the Enterprise platforms?
Salve, è possibile sapere se e quando pix4D capture sarà in grado di gestire le immagini termiche dell'Anafi Thermal?
Saluti Michele
I have a new Mavic Mini, and was planning to use it in place of the DJI 3 I've been mapping with before. Why is this drone "not compatible" for use with autonomous mapping software, such as yours? Thanks, Steve
I would like to know if the software is able to build 3d mosaics using the drone I own: Xiaomi Fimi x8 SE with Sony IMX378 sensor.
Bonjour, est ce que vous avez des nouvelles quant au support du Matrice 210 V2 RTK avec pix 4d? c
Salut Julien,
Toujours pas de progrès dans ce sens-là.
Je te recommande tout de même de jeter un coup d'oeil à cette discussion:
https://forum.dji.com/thread-192084-1-1.html
Cordialement
Hello,
Is there any plans to support the SlantRange multispectral camera's? Specifically the 4P and 4P+?
https://slantrange.com/product-sensor/
They can be used with the DJI skyport, and would this mean that your software could trigger the photographs to work?
Thanks
Bill - Australia
Hi Bill Heather,
What an impressive drone!
However in order to support a drone in Pix4Dcapture we need to have the SDK released which is not the case with this drone.
Once it will be released for sure it will be considered to add it to our pipeline.
Thank you for notifying us.
Best regards,
Bonjour, as t'on des nouvelles quant au support du m210v2 rtk ? Le drone est sortis il y a plus de 1 an et le SDK est disponible également.
Merci d'avance,
Julien
good morning, is it possible to use dji osmo to survey an interior?
Hello Chile I was wondering if Pix4D had a time line for Mavic air 2 compatibility?
Hy Bryan,
There are no plans to support Mavic air 2 in 2020. If things change, we will post here to inform the community.
Regards,
I own a Matrice 300 RTK, is there a reasonable and easy to understand answer to why the Matrice 300 RTK is not supported. I would appreciate a response
Bonjour,
Pix4D Fields ou Pix4D Mapper peut-il traiter les images de la camera DJI Phantom 4 Multispectral RTK?
Merci d'avance
Hello,
The Pix4Dmapper and Pix4Dfields both support the processing of images from the DJI Phantom 4 Multispectral RTK camera.
Best,
Hello there,
is Mavic 2 Enterprise DUAL really supported? I cannot access camera view, all I can see is black screen. Drone is connected to app and I can see telemtric data. Any advice how to solve this?
Thank you very much.
Ivan
