Supported drones, cameras and controllers - PIX4Dcapture
Information: PIX4Dmapper, PIX4Dcloud, PIX4Dmatic, PIX4Dreact, and PIX4Dfields can process images taken virtually from any image acquisition app. So, if PIX4Dcapture doesn't support the drone, the drone pilot can use any other image acquisition app to capture the images and then use PIX4D Photogrammetry software such as PIX4Dmapper, PIX4Dcloud, PIX4Dmatic, PIX4Dreact, and PIX4Dfields for processing the dataset. For more information see which image acquisition app can I use with Pix4D's software?
The status of Pix4Dcapture regarding the different drones, cameras, and controllers is described in the table below. When the app has not been tested, it means that the app could work but Pix4D makes no guarantee.
If a non-DJI camera is mounted on DJI drones, Pix4Dcapture will not be able to trigger the camera. Making it work will rely on the fact that a time-lapse can be set in this custom camera. A specific functionality has been developed on iOS to keep the right overlap up to the camera specifications. More information here.
Manufacturer Drone / Camera / Controllers Android iOS
DJI drones Inspire 1 (X3, X5, XT) Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Inspire 2 (X4S, X5S) Compatible (3.8.1 and later) Compatible (1.7.1 and later)
Mavic Air Compatible (4.3.0 and later) Compatible (3.2.0 and later)
Mavic Air 2 Not compatible Not compatible
Mavic Mini Not compatible Not compatible
Mavic Pro Compatible (3.5.0 and later) Compatible (1.6.0 and later)
Mavic 2 Pro Compatible (4.5.0 and later) Compatible (4.1.0 and later)
Mavic 2 Zoom Not compatible Not compatible
Mavic 2 Enterprise (Zoom) Not compatible Not compatible
Mavic 2 Enterprise (Dual) Not compatible Compatible only with RGB (4.7.0 and later)
Mavic 3 Not compatible Not compatible
Matrice 100 (X3, X5, XT) Compatible (3.1.1 and later) Compatible (1.4.0 and later)
Matrice 200 Compatible (4.1.1 and later) Compatible (2.9.2 and later)
Matrice 200 V2 series Not compatible Compatible - Not tested (4.10.0 and later)
Matrice 210 Compatible (4.1.1 and later) Compatible (2.9.2 and later)
Matice 210 V2 Not tested Not tested
Matrice 210 RTK Compatible (4.1.1 and later) Compatible (2.9.2 and later)
Matrice 300 RTK Not compatible Not compatible
Matrice 600 (X3, X5, XT) Not tested Compatible (2.0.0 and later)
Phantom 1 Not compatible Not compatible
Phantom 2 Not compatible Not compatible
Phantom 2 Vision Not compatible Not compatible
Phantom 2 Vision+ Not compatible Not compatible
Phantom 3 Advanced Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Phantom 3 Professional Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Phantom 3 Standard Compatible (3.1.0 and later) Compatible (1.0.0 and later)
Phantom 3 4K Not tested Not tested
Phantom 4 Compatible (3.1.0 and later) Compatible (1.2.0 and later)
Phantom 4 Advanced Not tested Not tested
Phantom 4 Pro V1 Compatible (3.6.0 and later) Compatible (1.6.1 and later)
Phantom 4 Pro+ V1 Not tested Not compatible
Phantom 4 Pro V2.0 Compatible (4.3.2 and later) Compatible (3.4.0 and later)
Phantom 4 Pro+ V2.0 Not compatible Not compatible
P4 Multispectral  Not compatible Not compatible
Spark (Free flight mission only) Compatible (3.8.5 and later) Compatible (2.3.0 and later)
DJI cameras Zenmuse XT Compatible (3.6.0 and later) Compatible (2.0.0 and later)
Zenmuse XT2 Not compatible Compatible - Not tested (4.10.0 and later)
Zenmuse X3 Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Zenmuse X4S Compatible (3.8.1 and later) Compatible (1.7.1 and later)
Zenmuse X5 Compatible (2.1.1 and later) Compatible (1.2.0 and later)
Zenmuse X5R Not tested Not tested
Zenmuse X5S Not tested, compatible (3.8.1 and later) Compatible (1.7.1 and later)
Zenmuse X7 Not compatible Not compatible
Zenmuse Z3 Not compatible Compatible - Not tested (4.10.0 and later)
Zenmuse Z30 Not compatible Compatible - Not tested (4.10.0 and later)
DJI controllers Smart controller Not compatible Not compatible
Parrot drones Anafi Compatible (4.4.0 and later) Compatible (4.0.0 and later)
Anafi Thermal (RGB+ Thermal images) Compatible (4.8.0 and later) Compatible (4.8.0 and later)
Anafi USA (RGB only) Compatible (4.10.0 and later) Compatible (4.11.0 and later)
Bebop 1 Not compatible Not compatible
Bebop 2 using Wifi Not compatible Not compatible
Bebop 2 with Skycontroller 2 Compatible (2.1.1 and later) Compatible (1.1.0 and later)
Bluegrass Compatible (4.1.0 and later) Compatible (2.7.0 and later)
Disco Not compatible Not compatible
Disco-Pro AG Not compatible Compatible (2.0.0 and later)
Parrot controllers Skycontroller Not compatible Not compatible
Skycontroller 2 Compatible (3.8.0 and later) Compatible (1.6.0 and later)
Skycontroller 3 Compatible (4.4.0 and later) Compatible (4.0.0 and later)
Yuneec drones H520 Compatible (4.2.0 and later) Not compatible
Yuneec cameras E90 Compatible (4.2.0 and later) Not compatible
Yuneec controllers ST16, ST16S Compatible (4.2.0 and later) Not compatible
3DR Solo (GoPro Hero 4 Black or Silver) Not compatible Not compatible (no iOS SDK)
Recommendations to fly a drone that was not tested
The drone to be selected before starting a mission should be one of those having the same connection mode (Wi-Fi or USB cable).
Tip: The following drones are not officially supported by Pix4Dcapture. However, you may be able to fly your mission if you select the appropriate settings in Pix4Dcapture:
  • DJI Phantom 3 4K: Select Phantom 3 Advanced or Professional in Pix4Dcapture's settings.
  • DJI Phantom 4 Advanced: Select Phantom 4 Pro in Pix4Dcapture's settings.
  • DJI Matrice 600: Select Matrice 100 in Pix4Dcapture's settings.
90 out of 115 found this helpful
123 comments
  • Bernd Bartusevics
    Hi everybody!
    Hm...as it looks DJI Mavic Air 2 is not supported at the moment!
    Will it ever?
    Kind regards,
    Bernd
  • Rania Labib
    I just bought two drones, one for personal use (the Mavic Zoom) and the other for my university lab (Matrice 300 RTK with P1 and XT2). I'm disappointed that both aren't supported by Pix4D. Could you please advise if there are any plans for supporting both drones? I appreciate a response. Thank you!
  • Marco Paccagnella
    Hi Rania,
    Unfortunately, there are no plans to support these drones.
    Please keep in mind that our image processing software can process images taken from virtually any application as long as they are of good quality and overlap. For more information: Which image acquisition app can I use with Pix4D's software?.
