Supported drones, cameras and controllers
The status of Pix4Dcapture regarding the different drones, cameras, and controllers is described in the table below. When the app has not been tested, it means that the app could work but Pix4D makes no guarantee.
Information: If a Non-DJI camera is mounted on DJI drones, Pix4Dcapture will not be able to trigger the camera. Making it work will rely on the fact that a timelapse can be set in this custom camera. A specific functionality has been developed on iOS to keep the right overlap up to the camera specifications. More information here.
If the Pix4Dcapture app does not support your drone, you can use any other image acquisition software and still process the data using Pix4Dmapper. Pix4D's software is drone/app agnostic, meaning that you will be able to process image data obtained from different image acquisition app or the drone. For more information see which image acquisition app can I use with Pix4D's software?
Manufacturer Drone / Camera / Controllers Android iOS
DJI drones Inspire 1 (X3, X5, XT) Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Inspire 2 (X4S, X5S) Compatible (3.8.1 and later) Compatible (1.7.1 and later)
Mavic Air Compatible (4.3.0 and later) Compatible (3.2.0 and later)
Mavic Air 2 Not compatible Not compatible
Mavic Mini Not compatible Not compatible
Mavic Pro Compatible (3.5.0 and later) Compatible (1.6.0 and later)
Mavic 2 Pro Compatible (4.5.0 and later) Compatible (4.1.0 and later)
Mavic 2 Zoom Not compatible Not compatible
Mavic 2 Enterprise (Zoom) Not compatible Not compatible
Mavic 2 Enterprise (Dual) Not compatible Compatible only with RGB (4.7.0 and later)
Matrice 100 (X3, X5, XT) Compatible (3.1.1 and later) Compatible (1.4.0 and later)
Matrice 200 Compatible (4.1.1 and later) Compatible (2.9.2 and later)
Matrice 200 V2 series Not compatible Compatible - Not tested (4.10.0 and later)
Matrice 210 Compatible (4.1.1 and later) Compatible (2.9.2 and later)
Matice 210 V2 Not tested Not tested
Matrice 210 RTK Compatible (4.1.1 and later) Compatible (2.9.2 and later)
Matrice 300 RTK Not compatible Not compatible
Matrice 600 (X3, X5, XT) Not tested Compatible (2.0.0 and later)
Phantom 1 Not compatible Not compatible
Phantom 2 Not compatible Not compatible
Phantom 2 Vision Not compatible Not compatible
Phantom 2 Vision+ Not compatible Not compatible
Phantom 3 Advanced Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Phantom 3 Professional Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Phantom 3 Standard Compatible (3.1.0 and later) Compatible (1.0.0 and later)
Phantom 3 4K Not tested Not tested
Phantom 4 Compatible (3.1.0 and later) Compatible (1.2.0 and later)
Phantom 4 Advanced Not tested Not tested
Phantom 4 Pro V1 Compatible (3.6.0 and later) Compatible (1.6.1 and later)
Phantom 4 Pro+ V1 Not tested Not compatible
Phantom 4 Pro V2.0 Compatible (4.3.2 and later) Compatible (3.4.0 and later)
Phantom 4 Pro+ V2.0 Not compatible Not compatible
P4 Multispectral  Not compatible Not compatible
Spark Compatible (3.8.5 and later) Compatible (2.3.0 and later)
DJI cameras Zenmuse XT Compatible (3.6.0 and later) Compatible (2.0.0 and later)
Zenmuse XT2 Not compatible Compatible - Not tested (4.10.0 and later)
Zenmuse X3 Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Zenmuse X4S Compatible (3.8.1 and later) Compatible (1.7.1 and later)
Zenmuse X5 Compatible (2.1.1 and later) Compatible (1.2.0 and later)
Zenmuse X5R Not tested Not tested
Zenmuse X5S Not tested, compatible (3.8.1 and later) Compatible (1.7.1 and later)
Zenmuse X7 Not compatible Not compatible
Zenmuse Z3 Not compatible Compatible - Not tested (4.10.0 and later)
Zenmuse Z30 Not compatible Compatible - Not tested (4.10.0 and later)
DJI controllers Smart controller Not compatible Not compatible
Parrot drones Anafi Compatible (4.4.0 and later) Compatible (4.0.0 and later)
Anafi Thermal (RGB+ Thermal images) Compatible (4.8.0 and later) Compatible (4.8.0 and later)
Anafi USA Compatible (4.10.0 and later) Compatible (4.11.0 and later)
Bebop 1 Not compatible Not compatible
Bebop 2 using Wifi Not compatible Not compatible
Bebop 2 with Skycontroller 2 Compatible (2.1.1 and later) Compatible (1.1.0 and later)
Bluegrass Compatible (4.1.0 and later) Compatible (2.7.0 and later)
Disco Not compatible Not compatible
Disco-Pro AG Not compatible Compatible (2.0.0 and later)
Parrot controllers Skycontroller Not compatible Not compatible
Skycontroller 2 Compatible (3.8.0 and later) Compatible (1.6.0 and later)
Skycontroller 3 Compatible (4.4.0 and later) Compatible (4.0.0 and later)
Yuneec drones H520 Compatible (4.2.0 and later) Not compatible
Yuneec cameras E90 Compatible (4.2.0 and later) Not compatible
Yuneec controllers ST16, ST16S Compatible (4.2.0 and later) Not compatible
3DR Solo (GoPro Hero 4 Black or Silver) Not compatible Not compatible (no iOS SDK)
Recommendations to fly a drone that was not tested
The drone to be selected before starting a mission should be one of those having the same connection mode (Wi-Fi or USB cable).
Tip: The following drones are not officially supported by Pix4Dcapture. However, you may be able to fly your mission if you select the appropriate settings in Pix4Dcapture:
  • DJI Phantom 3 4K: Select Phantom 3 Advanced or Professional in Pix4Dcapture's settings.
  • DJI Phantom 4 Advanced: Select Phantom 4 Pro in Pix4Dcapture's settings.
  • DJI Matrice 600: Select Matrice 100 in Pix4Dcapture's settings.
66 out of 90 found this helpful
106 comments
  • Kapil (Pix4D)
    Hello Ivan,
    The Mavic 2 Enterprise is only supported on the iOS version of Pix4Dcapture. However, the Pix4Dcapture app is only compatible with the RGB camera. If you have any issues, I would suggest you go through all the basic checks and troubleshooting steps as it will solve most of the issues that can be encountered if properly followed.
    Regards,
  • Gabriel Martins Genovez
    Gostaria de saber se tem compatibilidade com o drone fimi x8 se dá xiaomi
  • Kapil (Pix4D)
    Hi Gabriel, It is not compatible with Xiaomi FIMI X8.
  • Juan Arce
    Hello I want to know if the mvick air 2 will be support at some point?
    thanks
  • Fernanda Bosmediano
    Hi Juan,
    Supporting the DJI Mavic Air 2 is not in our roadmap for this year. If we support this drone, we will notify our users in our social media.
    Kind regards,
  • Wilmer Johan Hernandez
    Hola
    Tengo un dron Phantom 3 estandar y actualmente no me deja realizar el plan de vuelo con la aplicación Pix4Dcapture
  • Kapil (Pix4D)
    Hello,
    The behavior you are describing can’t be replicated on our side and has not been reported to us so far. I would suggest you go through all the [basic checks and troubleshooting steps] as it will solve most of the issues that can be encountered if properly followed.
    Regards,
  • Yohan Jang
    Hello,
    Will skydio 2 be supported by pix4d?
    Thanks.
    Hi,
    The Skydio 2 is not supported by Pix4Dcapture at the moment and it is currently not in our pipeline to support it. However, your interest has been shared with the team and any updates will be published on this page.
  • Gianni Gregoris
    Hi
    In future there are any possibilty tha Pix4d can be avaible on Dji Matrice 300 RTK ?
    If yes, When ?
    Thanks and bestregards
  • Kapil (Pix4D)
    Hello Gianni,
    The DJI Matrice 300 RTK  is not supported by pix4Dcapture at the moment and it is currently not in our pipeline to support it by the first quarter of 2021. If things change, we will publish it at our page on Supported drones, cameras and controllers
    I would also recommend you to go through our support article on Which image acquisition app can I use with Pix4D’s software?.
  • Mubashshir Zaman
    Hi,
    Since the SDK for the DJI Mavic Mini has been available since the end of July 2020, I was wondering whether or not Pix4d were working to make it compatible with the application. I know many people, including myself, would love to see Pix4d be compatible with the mini drone.
  • Gustavo Salvador
    Buenos días..
    Cuando podremos soportar el DJI Mavic Air 2 con la app de Pix4d capture,
    Cuando harán la actualización?
  • Christina (Pix4D)
    There are no plans for the Pix4Dcapture app to support the DJI Mavic Air 2 in 2020.
    You can find more information on our forum
    Edited by Christina (Pix4D)
  • bsyrt immas
    Since the upgrading of Anafi Parrot to firmware 1.7, Pix4D mapper is not working anymore on Android
  • Kapil (Pix4D)
    Hello,
    The Parrot Anafi won't work with the recent firmware update of 1.7.3. We will release a new version for Pix4Dcapture android within a few weeks and it should work with that version.
    For now, the only option is not updating the firmware to 1.7 or using the iOS version of the Pix4Dcapture app.
    Regards,
