Supported drones, cameras and controllers - PIX4Dcapture
Information: PIX4Dmapper, PIX4Dcloud, PIX4Dmatic, PIX4Dreact, and PIX4Dfields can process images taken virtually from any image acquisition app. So, if PIX4Dcapture doesn't support the drone, the drone pilot can use any other image acquisition app to capture the images and then use PIX4D Photogrammetry software such as PIX4Dmapper, PIX4Dcloud, PIX4Dmatic, PIX4Dreact, and PIX4Dfields for processing the dataset. For more information see which image acquisition app can I use with Pix4D's software?
The status of Pix4Dcapture regarding the different drones, cameras, and controllers is described in the table below. When the app has not been tested, it means that the app could work but Pix4D makes no guarantee.
If a non-DJI camera is mounted on DJI drones, Pix4Dcapture will not be able to trigger the camera. Making it work will rely on the fact that a time-lapse can be set in this custom camera. A specific functionality has been developed on iOS to keep the right overlap up to the camera specifications. More information here.
Manufacturer Drone / Camera / Controllers Android iOS
DJI drones Inspire 1 (X3, X5, XT) Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Inspire 2 (X4S, X5S) Compatible (3.8.1 and later) Compatible (1.7.1 and later)
Mavic Air Compatible (4.3.0 and later) Compatible (3.2.0 and later)
Mavic Air 2 Not compatible Not compatible
Mavic Mini Not compatible Not compatible
Mavic Pro Compatible (3.5.0 and later) Compatible (1.6.0 and later)
Mavic 2 Pro Compatible (4.5.0 and later) Compatible (4.1.0 and later)
Mavic 2 Zoom Not compatible Not compatible
Mavic 2 Enterprise (Zoom) Not compatible Not compatible
Mavic 2 Enterprise (Dual) Not compatible Compatible only with RGB (4.7.0 and later)
Mavic 3 Not compatible Not compatible
Matrice 100 (X3, X5, XT) Compatible (3.1.1 and later) Compatible (1.4.0 and later)
Matrice 200 Compatible (4.1.1 and later) Compatible (2.9.2 and later)
Matrice 200 V2 series Not compatible Compatible - Not tested (4.10.0 and later)
Matrice 210 Compatible (4.1.1 and later) Compatible (2.9.2 and later)
Matice 210 V2 Not tested Not tested
Matrice 210 RTK Compatible (4.1.1 and later) Compatible (2.9.2 and later)
Matrice 300 RTK Not compatible Not compatible
Matrice 600 (X3, X5, XT) Not tested Compatible (2.0.0 and later)
Phantom 1 Not compatible Not compatible
Phantom 2 Not compatible Not compatible
Phantom 2 Vision Not compatible Not compatible
Phantom 2 Vision+ Not compatible Not compatible
Phantom 3 Advanced Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Phantom 3 Professional Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Phantom 3 Standard Compatible (3.1.0 and later) Compatible (1.0.0 and later)
Phantom 3 4K Not tested Not tested
Phantom 4 Compatible (3.1.0 and later) Compatible (1.2.0 and later)
Phantom 4 Advanced Not tested Not tested
Phantom 4 Pro V1 Compatible (3.6.0 and later) Compatible (1.6.1 and later)
Phantom 4 Pro+ V1 Not tested Not compatible
Phantom 4 Pro V2.0 Compatible (4.3.2 and later) Compatible (3.4.0 and later)
Phantom 4 Pro+ V2.0 Not compatible Not compatible
P4 Multispectral  Not compatible Not compatible
Spark (Free flight mission only) Compatible (3.8.5 and later) Compatible (2.3.0 and later)
DJI cameras Zenmuse XT Compatible (3.6.0 and later) Compatible (2.0.0 and later)
Zenmuse XT2 Not compatible Compatible - Not tested (4.10.0 and later)
Zenmuse X3 Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Zenmuse X4S Compatible (3.8.1 and later) Compatible (1.7.1 and later)
Zenmuse X5 Compatible (2.1.1 and later) Compatible (1.2.0 and later)
Zenmuse X5R Not tested Not tested
Zenmuse X5S Not tested, compatible (3.8.1 and later) Compatible (1.7.1 and later)
Zenmuse X7 Not compatible Not compatible
Zenmuse Z3 Not compatible Compatible - Not tested (4.10.0 and later)
Zenmuse Z30 Not compatible Compatible - Not tested (4.10.0 and later)
DJI controllers Smart controller Not compatible Not compatible
Parrot drones Anafi Compatible (4.4.0 and later) Compatible (4.0.0 and later)
Anafi Thermal (RGB+ Thermal images) Compatible (4.8.0 and later) Compatible (4.8.0 and later)
Anafi USA (RGB only) Compatible (4.10.0 and later) Compatible (4.11.0 and later)
Bebop 1 Not compatible Not compatible
Bebop 2 using Wifi Not compatible Not compatible
Bebop 2 with Skycontroller 2 Compatible (2.1.1 and later) Compatible (1.1.0 and later)
Bluegrass Compatible (4.1.0 and later) Compatible (2.7.0 and later)
Disco Not compatible Not compatible
Disco-Pro AG Not compatible Compatible (2.0.0 and later)
Parrot controllers Skycontroller Not compatible Not compatible
Skycontroller 2 Compatible (3.8.0 and later) Compatible (1.6.0 and later)
Skycontroller 3 Compatible (4.4.0 and later) Compatible (4.0.0 and later)
Yuneec drones H520 Compatible (4.2.0 and later) Not compatible
Yuneec cameras E90 Compatible (4.2.0 and later) Not compatible
Yuneec controllers ST16, ST16S Compatible (4.2.0 and later) Not compatible
3DR Solo (GoPro Hero 4 Black or Silver) Not compatible Not compatible (no iOS SDK)
Recommendations to fly a drone that was not tested
The drone to be selected before starting a mission should be one of those having the same connection mode (Wi-Fi or USB cable).
Tip: The following drones are not officially supported by Pix4Dcapture. However, you may be able to fly your mission if you select the appropriate settings in Pix4Dcapture:
  • DJI Phantom 3 4K: Select Phantom 3 Advanced or Professional in Pix4Dcapture's settings.
  • DJI Phantom 4 Advanced: Select Phantom 4 Pro in Pix4Dcapture's settings.
  • DJI Matrice 600: Select Matrice 100 in Pix4Dcapture's settings.
90 out of 115 found this helpful
123 comments
  • Godfrin Bernard
    Bonjour,
    Nous avons déjà réalisé plusieurs vols avec PIX4D et hier lors de nos séances de vols les photos sont toutes floues alors que nous n'avons touché à aucun réglage donc je ne peux traiter aucune image.
    Pour info nous avons un matrice 210 RTK avec zenmuse X5S.
    Cordialement
  • Avatar
    Gaël (Pix4D)
    Bonjour Bernard,
    Nous avons répondu à votre requête via notre système de support.
    Salutations,
  • Dmitry Posledov
    Hello! I have a question about camera angle on my P3A drone. In Pix4Capture I don't know where I can change camera angle for example in circular missions. Camera set by 80 degrees, but I need a less value. In "eStarting manual describes what a value angle set by 45 degree and 30 degree. How can i do this?
    This is the picture from your "Getting started.." - So I can't do this. Can I change camera angle or this is goinf on automatically?
    Edited by Dmitry Posledov
  • Avatar
    Gaël (Pix4D)
    Hello Dmitry,
    The tilting angle of the camera can not be set for circular missions. It is implemented so that the camera will face the center of the mission, looking at the ground all the time.
    For other missions, the tilting angle can be set in the settings.
    You can have a look at the different parameters for Android or iOS.
    Best,
  • Mavic Reklamasi
    Hi, selamat malam, saya pengguna mavic 2 pro ketika saya buka pix4d capture dan melakukan misi tampilan kamera nya tidak ada, hanya ada layar blank hitam saja. Kira kira apa ya masalah nya? Sebelumnya saya pake p4 pro tidak ada masalah seperti ini. Tolong solusi nya. Terima kasih
    PS : pakai handphone android blackshark 2
    Edited by Mavic Reklamasi
  • Avatar
    Gaël (Pix4D)
    @Mavic Reklamasi,
    The live video feed for the Mavic 2 Pro has not been implemented on the Android version of Pix4Dcapture. It is then normal that you will see a black screen when looking at it.
    Best,
  • Mavic Reklamasi
    When will be implemented on mavic 2 pro? Is iOS support for live video on pix4d capture?
  • Avatar
    Gaël (Pix4D)
    Hi Mavic Reklamasi,
    Currently, the video live feed is not working for the Mavic 2 Pro using the iOS version of Pix4Dcapture. It is a known issue that will be fixed in the next release.
    For the Android version of Pix4Dcapture, I can not give you any timeline when/if it will be implemented.
    Best,
  • krzychu nieważne
    Hi.
    I have mavic 2 zoom, and the app works fine. why table contains information, that is mavic 2 is not supported?
  • Avatar
    Gaël (Pix4D)
    Hi,
    The Mavic 2 Zoom is not officially supported by Pix4Dcapture as we did not test it with our app. It might work with it but we make no guarantee. Also, as it is a zoom drone, the focal length might change during an acquisition and impact the image process and outputs afterward.
  • Keegan Brophy
    Will Pix4D support the mavic mini in the future?
  • Avatar
    Gaël (Pix4D)
    Hi Keegan,
    So far this drone has just been released so we need to evaluate if we will support it with Pix4Dcapture. In any case, DJI needs to provide an SDK that would enable third-party apps like Pix4Dcapture to be able to support the Mavic Mini, which is not the case for the moment.
    Best
  • Ariel Rossi
    Hello, I would like to know if mavic mini will be supported by Pixel4D? I'm interested in using the drone for mappings.
  • Avatar
    Gaël (Pix4D)
    Hi Ariel,
    Don't hesitate to open a thread on our community to talk about this topic.
    Best,
  • William Bush
    Has there been any additional insight as to when we could expect functionality with the Matrice V2 Series aircraft? Considering its versatility, I can not believe that it has not been added as a priority for compatibility. Is Pix4D just not going to work with the Enterprise platforms?
  • Mestroni Michele
    Salve, è possibile sapere se e quando pix4D capture sarà in grado di gestire le immagini termiche dell'Anafi Thermal?
    Saluti Michele
  • Steven Thompson
    I have a new Mavic Mini, and was planning to use it in place of the DJI 3 I've been mapping with before.  Why is this drone "not compatible" for use with autonomous mapping software, such as yours?  Thanks, Steve
  • gustavo martins
    I would like to know if the software is able to build 3d mosaics using the drone I own: Xiaomi Fimi x8 SE with Sony IMX378 sensor.
  • Julien Parini
    Bonjour, est ce que vous avez des nouvelles quant au support du Matrice 210 V2 RTK avec pix 4d? c
  • Avatar
    Marco (Pix4D)
    Salut Julien,
    Toujours pas de progrès dans ce sens-là.
    Je te recommande tout de même de jeter un coup d'oeil à cette discussion:
    https://forum.dji.com/thread-192084-1-1.html
    Cordialement
  • Bill Heather
    Hello,
    Is there any plans to support the SlantRange multispectral camera's? Specifically the 4P and 4P+?
    https://slantrange.com/product-sensor/
    They can be used with the DJI skyport, and would this mean that your software could trigger the photographs to work?
    Thanks
    Bill - Australia
  • Avatar
    Marco (Pix4D)
    Hi Bill Heather,
    What an impressive drone!
    However in order to support a drone in Pix4Dcapture we need to have the SDK released which is not the case with this drone.
    Once it will be released for sure it will be considered to add it to our pipeline.
    Thank you for notifying us.
    Best regards,
  • Julien Parini
    Bonjour, as t'on des nouvelles quant au support du m210v2 rtk ? Le drone est sortis il y a plus de 1 an et le SDK est disponible également.
    Merci d'avance,
    Julien
  • Mauro Cacciamani
    good morning, is it possible to use dji osmo to survey an interior?
  • Bryan Rodgers
    Hello Chile I was wondering if Pix4D had a time line for Mavic air 2 compatibility?
  • Kapil (Pix4D)
    Hy Bryan,
    There are no plans to support Mavic air 2 in 2020. If things change, we will post here to inform the community.
    Regards,
  • Moe Dastranj
    I own a Matrice 300 RTK, is there a reasonable and easy to understand answer to why the Matrice 300 RTK is not supported. I would appreciate a response
  • lou perrier
    Bonjour,
    Pix4D Fields ou Pix4D Mapper peut-il traiter les images de la camera DJI Phantom 4 Multispectral RTK?
    Merci d'avance
  • Kapil (Pix4D)
    Hello,
    The Pix4Dmapper and Pix4Dfields both support the processing of images from the DJI Phantom 4 Multispectral RTK camera.
    Best,
  • Ivan Neumann
    Hello there,
    is Mavic 2 Enterprise DUAL really supported? I cannot access camera view, all I can see is black screen. Drone is connected to app and I can see telemtric data. Any advice how to solve this?
    Thank you very much.
    Ivan
