Supported drones, cameras and controllers
The status of Pix4Dcapture regarding the different drones, cameras, and controllers is described in the table below. When the app has not been tested, it means that the app could work but Pix4D makes no guarantee.
Information: If a Non-DJI camera is mounted on DJI drones, Pix4Dcapture will not be able to trigger the camera. Making it work will rely on the fact that a timelapse can be set in this custom camera. A specific functionality has been developed on iOS to keep the right overlap up to the camera specifications. More information here.
Manufacturer Drone / Camera / Controllers Android iOS
DJI drones Inspire 1 (X3, X5, XT) Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Inspire 2 (X4S, X5S) Compatible (3.8.1 and later) Compatible (1.7.1 and later)
Mavic Air Compatible (4.3.0 and later) Compatible (3.2.0 and later)
Mavic Pro Compatible (3.5.0 and later) Compatible (1.6.0 and later)
Mavic 2 Pro Compatible (4.5.0 and later) Compatible (4.1.0 and later)
Mavic 2 Zoom Not compatible Not compatible
Mavic 2 Enterprise (Zoom) Not compatible Not compatible
Mavic 2 Enterprise (Dual) Not compatible Not compatible
Matrice 100 (X3, X5, XT) Compatible (3.1.1 and later) Compatible (1.4.0 and later)
Matrice 200 Compatible (4.1.1 and later) Compatible (2.9.2 and later)
Matrice 200 V2 series Not compatible Not compatible
Matrice 210 Compatible (4.1.1 and later) Compatible (2.9.2 and later)
Matrice 210 RTK Compatible (4.1.1 and later) Compatible (2.9.2 and later)
Matrice 600 (X3, X5, XT) Not tested Compatible (2.0.0 and later)
Phantom 1 Not compatible Not compatible
Phantom 2 Not compatible Not compatible
Phantom 2 Vision Not compatible Not compatible
Phantom 2 Vision+ Not compatible Not compatible
Phantom 3 Advanced Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Phantom 3 Professional Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Phantom 3 Standard Compatible (3.1.0 and later) Compatible (1.0.0 and later)
Phantom 3 4K Not tested Not tested
Phantom 4 Compatible (3.1.0 and later) Compatible (1.2.0 and later)
Phantom 4 Advanced Not tested Not tested
Phantom 4 Pro V1 Compatible (3.6.0 and later) Compatible (1.6.1 and later)
Phantom 4 Pro+ V1 Not tested Not compatible
Phantom 4 Pro V2.0 Compatible (4.3.2 and later) Compatible (3.4.0 and later)
Phantom 4 Pro+ V2.0 Not compatible Not compatible
Spark Compatible (3.8.5 and later) Compatible (2.3.0 and later)
DJI cameras Zenmuse XT Compatible (3.6.0 and later) Compatible (2.0.0 and later)
Zenmuse XT2 Not compatible Not compatible
Zenmuse X3 Compatible (2.0.6 and later) Compatible (1.0.0 and later)
Zenmuse X4S Compatible (3.8.1 and later) Compatible (1.7.1 and later)
Zenmuse X5 Compatible (2.1.1 and later) Compatible (1.2.0 and later)
Zenmuse X5R Not tested Not tested
Zenmuse X5S Not tested, compatible (3.8.1 and later) Compatible (1.7.1 and later)
Zenmuse X7 Not compatible Not compatible
Zenmuse Z3 Not compatible Not compatible
Zenmuse Z30 Not compatible Not compatible
DJI controllers Smart controller Not compatible Not compatible
Parrot drones Anafi Compatible (4.4.0 and later) Compatible (4.0.0 and later)
Anafi thermal (only RGB) Not compatible Compatible (4.5.0 and later)
Bebop 1 Not compatible Not compatible
Bebop 2 using Wifi Not compatible Not compatible
Bebop 2 with Skycontroller 2 Compatible (2.1.1 and later) Compatible (1.1.0 and later)
Bluegrass Compatible (4.1.0 and later) Compatible (2.7.0 and later)
Disco Not compatible Not compatible
Disco-Pro AG Not compatible Compatible (2.0.0 and later)
Parrot controllers Skycontroller Not compatible Not compatible
Skycontroller 2 Compatible (3.8.0 and later) Compatible (1.6.0 and later)
Skycontroller 3 Compatible (4.4.0 and later) Compatible (4.0.0 and later)
Yuneec drones H520 Compatible (4.2.0 and later) Not compatible
Yuneec cameras E90 Compatible (4.2.0 and later) Not compatible
Yuneec controllers ST16, ST16S Compatible (4.2.0 and later) Not compatible
3DR Solo (GoPro Hero 4 Black or Silver) Not compatible Not compatible (no iOS SDK)
Recommendations to fly a drone that was not tested
The drone to be selected before starting a mission should be one of those having the same connection mode (Wi-Fi or USB cable).
Tip: The following drones are not officially supported by Pix4Dcapture. However, you may be able to fly your mission if you select the appropriate settings in Pix4Dcapture:
  • DJI Phantom 3 4K: Select Phantom 3 Advanced or Professional in Pix4Dcapture's settings.
  • DJI Phantom 4 Advanced: Select Phantom 4 Pro in Pix4Dcapture's settings.
  • DJI Matrice 600: Select Matrice 100 in Pix4Dcapture's settings.
42 out of 58 found this helpful
75 comments
  • Gaël (Pix4D)
    Good evening from Switzerland,
    To be sure to answer you correctly, are you asking this question regarding the use of this camera with Pix4Dcapture which is the application to make automated flight plan using drones (this article is about Pix4Dcapture) or processing the images with Pix4D Mapper?
    Best,
  • Javier Guerra
    Hola Gael, específicamente es para procesar las imágenes en Pix4D Mapper.
  • Marco (Pix4D)
    Hola Javier,
    Por el momento esta cámara no está soportada en nuestra base de datos.
    Sin embargo, si conoce las especificaciones técnicas de su cámara, debería poder calibrarla:
    How-to-calibrate-a-Perspective-Lens-Camera
    How-to-calibrate-a-Fisheye-Lens-Camera
    Saludos
  • Marco (Pix4D)
    Hola Francisco,
    Todos los dispositivos compatibles con Pix4Dcapture se describen arriba. Por lo tanto, este modelo barato no es compatible con Pix4Dcapture.
    Saludos
  • KHURRUM KHAN
    Hi,
    Please inform, whether support for Mavic 2 Zoom is expected in future updates of Pix4D Capture??
    I've tried and successfully tested Mavic 2 Zoom on Drone Deploy Android app, but I'm more comfortable with Pix4D Capture, therefore I'm anxiously waiting for this support.....
    Thanks and Regards,
    Khurrum
  • Gaël (Pix4D)
    Hi,
    It is not in our pipeline to implement support for the DJI Mavic 2 Zoom at the moment. I would, therefore, recommend using any third-party app that can fit your needs in term of image acquisition.
    Note that Pix4D's image processing engine will be able to deal with any dataset as soon as you have a sufficient image overlap for your project.
    Best regards,
  • Miguel Carrillo
    For users of the mavic 2 zoom and your computer is not compatible with pix4D you can use the configuration of mavic pro ... it has worked very well for me on several flights that I have made ... greetings
  • Joakim Howlid
    When will M200 V2 be compatible?
  • Joakim Howlid
    When will XT2 be compatible?
  • Gaël (Pix4D)
    Hello Joakim,
    Currently, it is not in our pipeline to implement support for the XT2 camera. About the DJI Matrice 200 series V2, no decision has been made so far, I will share your interest with the developer's team and the Product Owner.
    Best,
  • Joakim Howlid
    Any plans for supporting the DJI Mavic 2 Enterprise Dual?
  • Gaël (Pix4D)
    Hi Joakim,
    At the moment, it is not in our pipeline to implement the support for the DJI Mavic 2 Enterprise Dual. I will also share your interest with the developer's team and the Product Owner for this drone.
  • Emiliano Debiassi
    I'd like to know if Anafi Thermal's RGB sensor will be supported in Android devices. If it does, do you have any idea when it will be available?
    Thank you.
  • Gaël (Pix4D)
    Hi Emiliano,
    It is currently not in the pipeline to support the Parrot Anafi thermal on the Android version of Pix4Dcapture. I will share your interest with the developer's team and the product owner.
    Best,
  • Jose Ripio
    Please make it happen the support of the PARROT ANAFI THERMAL for Android Pix4D Capture
  • Jonathan Mathieu
    Good day,
    Is Pix4DCapture is compatible with the new SDK remote controller for P4R?
    Thanks,
    J.
  • Gaël (Pix4D)
    Hi Jonathan,
    I guess you are mentioning the Phantom 4 RTK. Pix4Dcapture is not compatible for now with it but the team and the developers will evaluate the possibility to integrate it with our application in the future. So far no decisions have been made about it but I will share your interest with the Product Owner.
    Best,
  • Vianney Parsa
    Hola, tendrán noticias para la compatibilidad con Phantom 4 Pro+ V2.0?
    Edited by Vianney Parsa
  • Gaël (Pix4D)
    Hola Vianney,
    El estado sigue siendo el mismo para el P4P+ V2, lo que significa que no es compatible y no hay soluciones que podamos sugerir por el momento.
    Si desea utilizar Pix4Dcapture para hacer un plan de vuelo automatizado con su dron, entonces le sugiero que obtenga un Phantom 4 Pro V2 o cualquier otro dron que sea compatible con nuestra aplicación.
    Saludos
  • Jamieson Allen
    I am wondering if support will ever come for the Parrot Anafi Thermal and the DJI Mavic 2 Enterprise (Zoom)?
    I have both drones and cannot use either with your awesome software.
  • Gaël (Pix4D)
    Hi Allen,
    The Parrot Anafi thermal is supported on the iOS version of Pix4Dcapture since version V4.5.0. (only for RGB)
    About the Mavic 2 Zoom, I will share your interest with the Product Owner so that they consider to implement the support for it.
    Best,
  • Raffaele Dalessandri
    Buongiorno,
    è possibile sapere quando il PIX4DCattura sarà supportato dal Controller Intelligente della DJI? ho un Mavic 2 Pro e non riesco ancora a lavorare decentemente.
    Ti ringrazio.
    Raffaele
  • Gaël (Pix4D)
    Ciao Raffaele,
    Il DJI Smart controller non è al momento compatibile con Pix4Dcapture e non è nella nostra pipeline supportarlo per ora. Condividerò il tuo interesse con il nostro Product Owner e i nostri programmatori.
    Tieni presente che potrai utilizzare Pix4Dcapture con la nostra applicazione se disponi del controller di default del Mavic 2 Pro.
    Saluti
  • Alexandr Litovka
    Hello. I have phantom 3 pro. How i can fly with cameras foto settings 16:9? i don't wont fly with 4:3
  • Gaël (Pix4D)
    Hello Alexandr,
    Flying with Android or iOS version of Pix4Dcapture, the camera setting is set to 4:3 and there is no possibility to set it at 16:9 with our app.
    Best,
  • William Bush
    I know that it has been mentioned in other threads. However, has there been any decision on adding compatibility for the Matrice 200 V2? It is no longer possible to purchase the original, and moving forward I would prefer to remain with your data capture platform.
  • Gaël (Pix4D)
    Hi William,
    For now, no decision has been taken on our side. Be reassured that your interest has been shared with the Product Owner and we will communicate as soon as a decision will be taken for the support of the DJI Matrice 200 V2 series.
    Best regards,
  • HKD Geomatique
    Bonjour,
    Pouvez vous me dire quand ANAFI THERMAL sera pris en charge sur Android ?
    C'est un peu dure de préférer un OS à un autre.
    Merci d'avance.
  • Gaël (Pix4D)
    Bonjour,
    Nous n'avons pas de date à communiquer pour le moment quant à l'éventuel support du Parrot Anafi thermal.
    Le Parrot Anafi thermal est supporté sur la version iOS V4.5.0 de Pix4Dcapture (que les images RGB).
    Nous manquerons pas de tenir à jour cette page pour tout changement.
    Salutations,
