Index > Interface > Menu View > Index Calculator > Sidebar | Previous | Next |
On the left part of section 2. Regions, there is an arrow that allows the user to show/hide the section by clicking on it:
By default section 2. Regions is expanded and visible.
Section 2. Regions is collapsed and hidden.
- Selected region: Allows the user to select the region you want to edit.
- Draw: Allows the user to draw the selected region in the Index View.
- Clear: Allows the user to clear the drawn region in the Index View. Enabled if the selected region is drawn.
Formula Status icon: Next to the button Clear appears:
The region exists and is valid.
The region has not been drawn or the drawn area is incorrect (its edges intersect).
- Regions...: Opens the Region List pop-up, which allows the user to manage the regions:
- Add a new region.
- Delete an existing region.
- Edit the name of a region.
- Display some properties of the region.
- Import / export the regions.
Is there a way to NOT analyze a polygon within a developed region. Many fields have "unfarmed" islands in the middle of the field.
Hi, Unfortunately, it is not. You can add a region for the unfarmed lands in the middle and a region for the whole field. You could then subtract the min, max, average values of the unfarmed region from the total region.
