Error: "The NVIDIA OpenGL driver lost connection with the display driver due to exceeding the Windows Time-Out limit and is unable to continue."
Error
Description
Error while processing Step 1. Initial Processing:
Cause
This error occurs when the graphics card is selected for processing, but the GPU performance is much lower than the CPU performance. The workload sent from the CPU to the GPU is overloading the GPU.
A similar case is described here: NVIDIA OpenGL Driver Error: "Unable to recover from a kernel exception.".
Solution
There are several solutions:
1. Remove the use of the GPU for processing in the processing options:
1.1 On the menu bar, click Process > Processing Options...
1.2 Select the tab Resources and Notifications.
1.3 Unselect the graphics card listed.
1.4 Click OK.
2. Change the graphics card to a model more balanced with your CPU.
 For more information about the error: http://nvidia.custhelp.com/.
3 out of 18 found this helpful
