Error e0046: "Processing failed. No calibrated cameras."
Error
Description
When processing step 1. Initial Processing, the processing stops and shows the message: e0046: "Processing failed. No calibrated cameras."
Cause
No cameras could be calibrated. Possible causes:
  • The image quality is not sufficient (blurry images, no texture, etc.).
  • There is no overlap between the images.
  • The camera model associated to the cameras is not correct.
  • The image geolocation or coordinate system is not correct.
  • The GCP geolocation or coordinate system is not correct.
Solution
  • Verify that the image quality is sufficient. For more information: 203756115.
  • Verify that there is enough overlap between the images. For more information: 203756125.
  • Verify that the camera model associated to the camera is correct. For more information: 203032259.
  • Verify that the image geolocation and coordinate system is correct. For more information: 203755985.
  • Verify that the GCP geolocation and coordinate system is correct. For more information: 203032299.
1 out of 1 found this helpful
