Error e0046: "Processing failed. Only n% images have geolocation."
Error
Description
When processing step 1. Initial Processing, the processing stops and shows the message: e0046: "Processing failed. Only n% images have geolocation."
Cause
The Alternative Processing Mode (202557759) is used and there are not enough geolocated images.
Solution
Verify that at least 75% of the images have good geolocation. For more information: 203768475.
0 out of 0 found this helpful
Powered by Zendesk
