Error e0046: "Processing failed. Cannot open image."
Error
Description
When processing step 1. Initial Processing, the processing stops and shows the message: e0046: "Processing failed. Cannot open image <filename>."
Where <filename> is the name of an image of the project.
Cause
The image could not be opened because the image does not exist or the image file has no read permission.
Solution
Verify that the image exists and that the image file has read permission. For more information: 203032319.
0 out of 0 found this helpful
