Error e0046: "Processing failed. The images and GCPs do not lie in the same area."
Error
Description
When processing step 1. Initial Processing, the processing stops and shows the message: e0046: "Processing failed. The images and GCPs do not lie in the same area."
Cause
The images and GCPs do not lie in the same area. This can be due to:
  • Incorrect image geolocation / coordinate system.
  • Incorrect GCP geolocation / coordinate system.
Solution
  • Verify that the image geolocation and coordinate system is correct. For more information: 203755985.
  • Verify that the GCP geolocation and coordinate system is correct. For more information: 203032299.
0 out of 0 found this helpful
Powered by Zendesk
